Home > In Car Electronics (L322) > Satnav/TV/Radio Monitor -- Blank Screen
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Just come back from a week�s hols, went to start the RR and the Satnav/TV/Radio Monitor screen is blank
It�s a 2002 Vogue, when i switch the ignition on the system works, i can hear the radio perfectly change stations etc........it�s the screen, it stays blank, nothing showing on it at all except a change in the back light.
When i first started it it did flicker for a while then blank..........
I�ve checked the fuse, done the battery dis con re con bit, removed and reconnected the wiring plugs to the major components looking for dirty connections but still a blank screen.........
Anyone have a fix, can�t find a tread on here regarding this..........
Post #80918 13th Sep 2011 4:33pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Re: Satnav/TV/Radio Monitor -- Blank Screen
Probably the actual sat nav unit in the back. It's going to be a cd based mk3 - search here for the positive experiences people have had by upgrading it to a mk4 unit. It's a lot quicker and better in every way.
Post #81127 14th Sep 2011 9:17am
netsonic Steve
Well after a process of elimination starting with the components in the rear of the car I have found what was casing the blank screen
It was the blue plug socket of the TV Tuner.....moisture must have been getting in over the years and caused corrosion to one of the pins which was broken off in the socket when I inspected all the connections.......I was able to prove the screen was then active by plugging the blue plug from the TV tuner directly into the Sat Nav unit and hey presto screen was up and running albeit not having the TV on the menu as I had bypassed it temporarily
It�s a shame the TV Tuner Blue plug cannot reach the Sat Nav CD unit when it�s in its mount as I would have been happy to eliminate the TV from the circuit so I have bought a second hand analogue unit for �50 to get things connected back as it should be so the screen and functions can be used.............
Post #81615 15th Sep 2011 10:30pm
most sat nav/radio problems stem from water in the near side rear compartment...have you fitted a 'water shedder' yet...its a plastic bag thingy to keep water/moisture away from the electronics.. ... - .- -.
Post #81654 16th Sep 2011 8:26am
netsonic Steve
Just to conclude this post, new second-hand tuner arrived today, 5 mins to fit, screen, TV, comp, Sat Nav etc all working perfectly................shame my area switches to digital fully by Feb. 2012 lol..............
Post #82621 20th Sep 2011 4:25pm
Tall paul k
United Kingdom 2003 Range Rover Vogue Td6 Tonga Green
Going to try this on my 53 Vogue after finally finding your thread 👍
Post #550140 12th Apr 2020 9:28pm
