Home > General > TD6 Battery
Page 3 of 3 <123
Mr Tee
Think i'll give them a bell tomorrow.
Post #79156 4th Sep 2011 2:44pm
Googsy
scarey wrote:
the one i fitted and does the job very well is a bosch 020 with 110AH, 920CCA....so if that one gives you 130AH and 1000CCA then it does sound a good battery...just make sure the terminals are the correct way round....
I just fitted one of these to my 08 it was a tight fit ! I noticed the OEM version was 950CA with 1000 AH ( VARTA) . I was getting the ocassional "Special Programs off " message with a bong on start up. The problem is now gone. I have noticed the car runs even smoother than before. If the battery had not been charging properly or had a problem with a cell in the battery would this mean the engine may run rougher and burn more fuel ? I seem to be getting about 2- 3mpg more now.
can a bad battery cause so many of these issues such as rough running with more fuel being used ? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #80755 12th Sep 2011 8:59pm
swast4
Hi Mr Tee,
Did you order the battery 130Ah 1000CCA ? does it fit ok ?
Adam
Post #83634 24th Sep 2011 3:46pm
Page 3 of 3 <123
