![]() | Home > General > TD6 Battery |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Hi mate - I had issues with mine along with others on here. The original battery from LR is not big enough (power wise) really.
S11X TT Member Since: 02 Jul 2011 Location: North East Posts: 20 ![]() ![]() |
Thanks Ashley,
Europarts do the same battery under the bosch badge for £133.00 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
this is the one i got ..bosch s5 020 with 5 year warranty.. |
Ashley
Sorry mate - Yes I did. Very easy on line and fast delivery. From memory I think it was next day. I also ordered one for Mrs C's P38 and same story.
online is good, buying locally [if you can] is better ,if, the battery develops a fault you can take get it back easier for replacement..... |
Thanks.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
don't worry about the wasting money on a ABS ECU the HDC inactive message is pretty normal when the battery gets low.
Thanks for that, reassuring.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Yes. I have had this message appear briefly but have tried Hill Descent switch straight after and it works fine. So it would appear to be an erroneous message when the battery is a bit low. Incidentally if I turn the key and start the engine straight away it doesn't happen. If I turn the key and wait for the heater plug light to go out (a couple of seconds) the message often appears. In the summer the car will start immediately so the delay isn't needed. I haven't had the car for very long so don't know how it will behave in the winter yet.
yes as mike said your hill decent is fine.
Thanks. New battery arrived yesterday hopefully that will solve it.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 821 ![]() ![]() |
will that battery fit into a full fat MY2011? |
