Home > Technical (L322) > Car is shacking at idle !!!
J.Seven
Portugal 2003 Range Rover Vogue Td6 Monte Carlo Blue
Weird behaviour from my 2002 TD6. At idle the car is shacking while in "N", and it gets a bit worst in "D" but only at idle.
In "D" at idle it shakes and if take out the brake pedal it goes but in a weird manner not smoth at all for the first meters and then it gets normal while at speed.
What can it be???? J.Seven
Post #79919 8th Sep 2011 6:11pm
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
One of 6 injectors have failed, g/teed!! Have had this problem before, local indy charged me around £400 to replace with a new one Thumbs Up Although, he did say when one goes the others normally do........and mine is starting to show symptoms again Censored
TIP - whoever does it, get your old one back, you can have them refurbed for a fraction of the price of a newun Thumbs Up
Post #79923 8th Sep 2011 6:24pm
J.Seven
Today in the morning while engine was cold everything was normal, no shacking at all, after the engine warmed up it start shacking again at idle. I'm 300km away from home, is it safe to make the trip back home with this problem? J.Seven
Post #80032 9th Sep 2011 10:12am
RRPhil
You haven't just put larger wheels on your TD6 have you (i.e. bigger than 18")?
Phil
Post #80035 9th Sep 2011 10:24am
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
I was going to suggest wheels too. I took my Overfinch 22" ones off and now have a set of 2010/11 wheels on standard size and don't have the judder anymore. Thumbs Up 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #80036 9th Sep 2011 10:37am
J.Seven
Phil
No I didn't, it's the normal 18". J.Seven
Post #80037 9th Sep 2011 10:38am
J.Seven
As i said before i have the standart endros. I think it must he something related to the engine or gearbox/forque converter. J.Seven
Post #80039 9th Sep 2011 10:44am
liverpoolphil
its intermittent, just like mines doing at the moment. You will probably find if you put some injector cleaner in, it may well be ok for a short while, but it will cme back. Another symptom of faulty injectors is a strong smell of deisel upon start up in the morning
If you can get it fault read, that should tell you for definite Thumbs Up
Post #80044 9th Sep 2011 11:47am
