Home > Technical (L322) > Handbrake cable replacement?
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Hi all, my 2002 4.4 has just failed MOT, a brake hose, front ball joint, no issues and very cheap from british parts but the handbrake is causing headaches, Tried adjusting prior to MOT and couldn't get any handbrake. Replaced rear handbrake shoes and discs and whilst jacked up seemed ok but when on wheels no handbrake again. Self sdjustment seems to be working so friend suggests maybe the cable stretched due to being knackered so long.
Can't find any info on cost of handbrake cable or if difficult to fit? Any ideas suggestions welcomed as my free re test days are ticking down!!
Post #78948 3rd Sep 2011 8:22am
Cable costs around £30 from LR.
Wear gloves when fitting at the centre console as the metal surround is razor sharp
Post #78954 3rd Sep 2011 8:57am
Nickj
Thanks. Just rung a few pplaces and indeed 29.41 plus vat each. Can't get in till Tuesday though Sad
Any idea if a difficult job and whats required??
Post #78955 3rd Sep 2011 9:05am
Awkward more than difficult Big Cry
Need to remove rear wheel, caliper,disc, handbrake shoes and remove cable from expander. Loosen 10mm bolt at rear of backplate and pull old cable through, it may be seized, if so cut end nipple off cable and pull through, use a punch to remove metal sleve from backplate.
Remove rear panel of centre console, lock off handbrake adjuster with metal pin, remove insert from centre console remove the 2 bolts that hold centre console down. Lift centre console upwards to allow access to underneath, unhook old cable and pull out from underneath the car (you need to remove the heat shield to allow access to the cable).
Fitting is reversal
Post #78967 3rd Sep 2011 10:54am
47p2, i've placed this 'how to ' into the wiki with credit to you .
Post #78970 3rd Sep 2011 11:07am
Fresh in my memory after changing mine last week and still have the wounds from cutting my thumb on the sharp metal edge twice in the same place Big Cry
Post #78978 3rd Sep 2011 12:23pm
post a picture of your bloody thumb and i'll include that as well... Laughing
Post #78979 3rd Sep 2011 12:42pm
It was sore enough slicing through the first time but when the second cut sliced in at the exact same spot I almost cried Big Cry Big Cry
Real men don't wear gloves or cry Thumbs Up Thumbs Up Thumbs Up
Post #78998 3rd Sep 2011 3:09pm
Laughing
Post #78999 3rd Sep 2011 3:20pm
Nickj
Thanks. Great explanation Thumbs Up
Post #79166 4th Sep 2011 3:19pm
Nickj
All done and full ticket now. Thanks for help.
Post #80202 10th Sep 2011 8:04am
Glad you managed to get it sorted Thumbs Up Thumbs Up
Post #80230 10th Sep 2011 11:47am
