Home > Technical (L322) > rear view camera not working
BrianC
Re: finally working
uae wrote:
Hi
on mine it works now i had the software update done, my head-unit forgot it had a rear view camera just got the car back today,
thanks Thumbs Up Thumbs Up Thumbs Up
how much did it cost to get the update
Post #55641 19th Mar 2011 6:58pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
my rear view camera stopped working again Evil or Very Mad
If I go into reverse i see that:
or it looks first like that
and then it becames black
Post #60869 18th Apr 2011 3:33pm
If the power for the camera (when in reverse) comes from the reversing light will the camera fail if the reversing light bulb is blown?
Post #77996 28th Aug 2011 6:00pm
When we get a definite answer this may need to go in the WIKI.
More details on the update required would be useful?
Post #77997 28th Aug 2011 6:03pm
Also does the interior trim at the top of the rear tailgate (behind Rear view Camera) just pull off - if you pull hard enough or is there another method?
Post #78001 28th Aug 2011 6:23pm
The dealership wanted £500 off me to fix mine as i had the same problem , was told i needed a new camera Shocked
Post #78005 28th Aug 2011 6:33pm
Interesting for those wanting to add a RVC:
http://www.ebay.co.uk/itm/CAR-REAR-VIEW-CA...739wt_1018
This one actually looks like the Range Rover unit:
http://www.ebay.co.uk/itm/Car-8-LED-Night-...944wt_1095
And MercuryF1 fitted an non LR camera into the same place as Factory and it worked plug & play:
Quote:
managed to solve my reverse camera woes today without having to pay 400pounds to LR!
Went to a car accessory shop here in Malaysia. There was an array of cameras to choose from - ranging from 30 GBP to 200 GBP. What was great was there is no need to install an extra reverse cam screen. The image comes through to FFRR front touch screen!
Fitting took an hour the old faulty camera had to be removed from the original plastic casing to be replaced by the new unit. Plug and play! now I can SEE where I am reversing into now!
I opted for the expensive model as it captures a super-Wide image as well as has infra-red capability. Made in Korea, comes with a 2 year warranty! I will post some pics when I have more time.
Post #78007 28th Aug 2011 7:18pm
tolley
camera
https://vision-uk.co.uk/productPage.php?productId=145
any good
Post #78541 31st Aug 2011 6:37pm
Only fits Sporty!
Post #78549 31st Aug 2011 7:52pm
ric355
Gazellio wrote:
Only fits Sporty!
Unless my eyes deceive me, same is true for the one you posted on 28th?
Post #78576 31st Aug 2011 10:03pm
Yes the first link was just a Sporty/D3 looking back but I think the second link I posted may fit.
Worth noting that second hand cameras are available at reasonable prices.
Post #78591 1st Sep 2011 7:22am
