Home > Off Roading & Green Laning > Wading in an FFRR |
Stan, it looks like you're approaching a canal lock... RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
16th Aug 2011 11:18am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35339 |
that's the footpath/little bridge on the right...tbh i was a bit nervous going through as it was my virgin run.. |
16th Aug 2011 11:22am |
Thinking about this a little bit more,
28th Aug 2011 12:47pm |
tis drivers side but remember any water that does go in via the vent has to go slightly upwards as well and you can see from the pic that the water is fairly deep.. |
28th Aug 2011 1:39pm |
True, i guess when i do a service and gearbox fluid change soon i'll take the wing off and have a nice nosey around as its possible one of the pipes or bends is like the holed one for the RRS and D3/D4... |
28th Aug 2011 2:13pm |
are you expecting big floods up there in yorkshire.. |
28th Aug 2011 2:17pm |
If we don't learn from history, we can not make the future as good as it should be....
28th Aug 2011 2:23pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
I'd be making sure all your under body electric connections are watertight too if you are wading up to the limit e.g. Gearbox and shift motor for starters .
28th Aug 2011 2:25pm |
Should be water tight as 500mm is upto the underbody isn't it and then a smidge?? |
28th Aug 2011 2:38pm |
I'd like to know what's been changed in the newer ones to make them 700mm... At a guess I would guess just the air intake, but maybe other things? I have waded 70-80cm in the past in the FFRR, not for the light hearted. It's all about the bow wave. |
28th Aug 2011 2:45pm |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
sounds like you would be better off with an amphibious world war 2 type vehicle..... MY2010 TDV8 Vogue Ipanema Sand
24th Nov 2012 12:08pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
I had the idea of a disco 3 rai and i was going to machine a piece of ali block so where the vent is it would be painted body colour and smooth across that replaced the drivers wing vent but with the correct apperture for the rai and i think it would have looked right as opposed to looking a bodge lol but i only got as far as getting an old vent for measurements and a big block of ali billet onto no6 Range Rover
24th Nov 2012 2:12pm |
I have since found that an rai from the side grille won't work as the pipe work inside the wing is just loosely fitted.
24th Nov 2012 4:08pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Anyone done this with a FF yet?
24th Nov 2012 7:13pm |
