Home > Off Roading & Green Laning > Wading in an FFRR
Page 2 of 3 <123>
SteveMFr
Site Sponsor
scarey wrote:
it got a little bit deeper further on..
Stan, it looks like you're approaching a canal lock... Shocked
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #76448 16th Aug 2011 12:18pm
that's the footpath/little bridge on the right...tbh i was a bit nervous going through as it was my virgin run..
Post #76449 16th Aug 2011 12:22pm
Thinking about this a little bit more,
Which side does the TD6 breath from as im thinking if its like the drivers side, could the side vents just be removed and a mock up like this be made for short term usage??
http://www.disco3.co.uk/forum/topic14190.html
Post #77929 28th Aug 2011 1:47pm
tis drivers side but remember any water that does go in via the vent has to go slightly upwards as well and you can see from the pic that the water is fairly deep..
Post #77932 28th Aug 2011 2:39pm
True, i guess when i do a service and gearbox fluid change soon i'll take the wing off and have a nice nosey around as its possible one of the pipes or bends is like the holed one for the RRS and D3/D4...
Post #77945 28th Aug 2011 3:13pm
are you expecting big floods up there in yorkshire..
Post #77946 28th Aug 2011 3:17pm
If we don't learn from history, we can not make the future as good as it should be....
Floods seem to be a almost annual occurance in yorkshire, and at least 1 place in the uk every few months so i dont mind having a mash up just in case you see Smile
Now, just have to see how i can prep a twin axle 'van(bit like nbunny's) to either stop it floating, or put a keel or two underneath for water crossing lol!
Post #77950 28th Aug 2011 3:23pm
I'd be making sure all your under body electric connections are watertight too if you are wading up to the limit e.g. Gearbox and shift motor for starters .
Post #77951 28th Aug 2011 3:25pm
Should be water tight as 500mm is upto the underbody isn't it and then a smidge??
Post #77955 28th Aug 2011 3:38pm
dan_uk_1984
I'd like to know what's been changed in the newer ones to make them 700mm... At a guess I would guess just the air intake, but maybe other things?
I have waded 70-80cm in the past in the FFRR, not for the light hearted. It's all about the bow wave.
Post #77959 28th Aug 2011 3:45pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
In the older cars and brochures the wading depth was measured to the bottom of the intake vent grill, I wonder if they now measure the wading depth tho the actual height of the hole in the wing where the intake really is, which would also drown you very expensive Bi-Xenon headlamps................... 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #77962 28th Aug 2011 3:58pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
sounds like you would be better off with an amphibious world war 2 type vehicle..... MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #153112 24th Nov 2012 1:08pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
I had the idea of a disco 3 rai and i was going to machine a piece of ali block so where the vent is it would be painted body colour and smooth across that replaced the drivers wing vent but with the correct apperture for the rai and i think it would have looked right as opposed to looking a bodge lol but i only got as far as getting an old vent for measurements and a big block of ali billet onto no6 Range Rover
Everyone needs a hobby
Post #153137 24th Nov 2012 3:12pm
I have since found that an rai from the side grille won't work as the pipe work inside the wing is just loosely fitted.
My idea now is to either get a scrap bonnet or wing and then drill a hole through it and use a generic rai from that with a replacement a pillar trim as well to lift it up.
Then for the bonnet a sealing mechanism is needed for the interior air inlet. Because as soon as water is bonnet high any water will wash up it an drop straight into this intake soaking the filter and coming inside Sad
I'm thinking that it just needs a thin sheet of plastic that can fit snugly over it and seal it when the bonnet is down. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #153155 24th Nov 2012 5:08pm
Anyone done this with a FF yet?
Post #153189 24th Nov 2012 8:13pm
Page 2 of 3 <123>
