![]() | Home > Technical (L322) > Suspension Fault Alert - Normal Height Only |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
it would be bad luck if it was the compressor again, most likely something associated with it.. |
Could be a loose pipe to compressor if you only fitted recently. Present :2008 TDV8 HSE
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
+1 |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Wouldn't the compressor itself still be running though? Maybe a loose wire or blown fuse if comp not running at all. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
No loose pipes, no blown fuses or loose connections.....
UPDATE:
a battery on its last legs does cause a lot of problem so on the range, if its over 3 years old'ish, it might be worth getting a new one especially just before the winter sets in... |
I'm sure its the original battery so now nearly 6 years old, plus the car does a lot of short journeys now.....think I'll get a new one ![]() |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
WELL FINALLY I THINK MY BATTERY IS PACKING IN. I DIDDNT REPLACE THE BATTERY AND I WAS SURE THE CAR WAS TAKING LONGER TO TURN OVER. AFTER WHAT WAS A GOOD 3-4 SECONDS THE CAR TURNED OVER
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1025 ![]() |
