Home > Technical (L322) > Suspension Fault Alert - Normal Height Only
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I got the Suspension Fault message appear on the dash yesterday along with the Normal Height Only appearing.
Now I can't hear the compressor running at all and the car is stuck in normal height.
I replaced the compressor 2 months ago when i had the same issue, certainly hope it's not the compressor again Big Cry
I have tried disconnecting the battery but the fault is still there.......I guess it's a trip to my local Indy to get the fault codes read.
Here's hoping it's a sensor osomething cheap.......any ideas ??? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #77895 28th Aug 2011 7:40am
it would be bad luck if it was the compressor again, most likely something associated with it..
Post #77897 28th Aug 2011 8:43am
Googsy
Could be a loose pipe to compressor if you only fitted recently. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #77905 28th Aug 2011 9:38am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
+1
Post #77910 28th Aug 2011 10:36am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Wouldn't the compressor itself still be running though? Maybe a loose wire or blown fuse if comp not running at all. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #77915 28th Aug 2011 11:01am
CG-SC
No loose pipes, no blown fuses or loose connections.....
Either the compressor is gubbed again or something is inhibiting it's operation...... Evil or Very Mad Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #77917 28th Aug 2011 11:14am
CG-SC
UPDATE:
Well went out in the car this afternoon, the battery seemed to be quite low as it turned over very slugishly then fired up. Got the HDC alert as the battery was low, then it went out.
Then the compressor started running again and the suspension has been fine since Rolling Eyes
So now I'm wondering if my battery is on its last legs.........still not sure why I had the suspension issues yesterday...... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #77972 28th Aug 2011 4:22pm
a battery on its last legs does cause a lot of problem so on the range, if its over 3 years old'ish, it might be worth getting a new one especially just before the winter sets in...
Post #77995 28th Aug 2011 5:44pm
CG-SC
I'm sure its the original battery so now nearly 6 years old, plus the car does a lot of short journeys now.....think I'll get a new one Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #78008 28th Aug 2011 7:30pm
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
WELL FINALLY I THINK MY BATTERY IS PACKING IN. I DIDDNT REPLACE THE BATTERY AND I WAS SURE THE CAR WAS TAKING LONGER TO TURN OVER. AFTER WHAT WAS A GOOD 3-4 SECONDS THE CAR TURNED OVER
HDC INACIVE
THEN
THE
DREADED
INACTIVE AIR SUSPENSION AND IT WONT GO AWAY. I WOULD IMAGINE ITS BECAUSE THE BATTERY IS JUST Censored . Sad QUITE DEPRESSING.
ANYWAY I AM ABOUT THE ORDER A NEW BATTERY BUT JUST TO LET FORUM MEMBERS KNOW EURO CAR PARTS HAVE A 25% DISCOUNT RIGHT NOW ON ALL PARTS. THE PROMO CODE IS CRAZY25
IM GETTING THE BATTERY FOR 99 QUID INCLUDING DELIVERY HEHE
http://www.eurocarparts.com/ecp/c/Land+Rov...amp;000020
IM ASSUMING THIS IS KING OF THE BUNCH IN TERMS OF BATTERIES, I HAVE A 4.4 2004 V8. Very Happy
Post #85672 6th Oct 2011 7:07pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
HDC INACIVE
THEN
THE
DREADED
Censored , just bought one of these at full price! Censored 2012 SDV8 Vogue SE
Post #85675 6th Oct 2011 7:13pm
