![]() | Home > Technical (L322) > 2010MY on third set of discs/pads! |
Personally I would advise getting a nice set of LR 20" Wheels. |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
I think thats what may happen, Apart from the disc issues they are always needing balancing. Plus the cost of tyres! TDV8 HST Sport **Current** 4.4 V8 Autobiography and 22" wheels **Gone** |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
i would make the car standard [20'' wheels] and carry on claiming on the warranty.. |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
tis why i never went for 22"
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Does he use HDC a lot? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
or drive in flippers?
I cant see how 22" wheels would have any effect on the brakes. But as LR say, any deviation from factory and they are well within their rights to refuse related warranty work.
Nope TDV8 HST Sport **Current** 4.4 V8 Autobiography and 22" wheels **Gone** |
I loved the 22' wheels however like you say it compromised ride quality massively and yes they do easily damage on todays crap roads ![]() I've told him to buy a set of 20' wheels and take it back, personally i cant see how wheels that have the same rolling circ as stock can cause this. I think its an excuse! TDV8 HST Sport **Current** 4.4 V8 Autobiography and 22" wheels **Gone** |
Just a thought.
Yeah, as Dan and nicedayforit said the only way a wheel can functionally assist the heat dissipation is via hub to hub contact which would be the same regardless of wheel diameter and to be fair if that cooling were actually required the wheels would be hot every time you used them- in reality they are only hot when a brake has stuck on. |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2046 ![]() ![]() |
Brock |
Warped discs are mainly due to heat building up and not dissipating quickly enough. Always when stopped at traffic lights apply the handbrake and remove your foot from the brake pedal to allow the discs to cool down quicker, thus preventing potential hot spots. |
LR @ Brock claimed the issue was due to larger wheels not allowing the brakes to cool which tbh when i was told immediately thought was BS! Also seems the opinion here. As mentioned i cant see how wheels that just touch the hub would do this! Overfinch wont honour any part warranty for parts bought prior to their take over. He was told this when contacting about the wheel centres that corroded. ![]() I'll ask him to try the non braking test and see what happens, And also suggest he has a run out to Hillendale....... Or rings LR customer services to complain! TDV8 HST Sport **Current** 4.4 V8 Autobiography and 22" wheels **Gone** |
