Home > Technical (L322) > Reduced Engine Performance - Fuel Pump
Page 2 of 5 <12345>
Bob the B wrote:
Dan
After the other day try investing in one of these
http://www.ebay.co.uk/itm/170651940098?ssP...1438.l2648
'fraid its not that easy on a touch screen fuulfat..
Post #76907 21st Aug 2011 7:23am
mzplcg
SteveMFr wrote:
If it's a private individual it's quite likely that this was a known problem (what are the odds that the car - otherwise perfect - suddenly has this problem within hours of your taking ownership?).
And if it's from a dealer...
TBH, anyone who can afford to run a S/C FFRR isn't going to be worried by a garage bill or two.
Dan's probably right, some of the old Jag XJ's used to do this. Keep the tank more than half full and happy days but let the fuel level drop and the pump would overheat. I had 2 XJR's and they both did this. It's not even a tough fix really, tedious but not overly hard work. The pumps aren't overly expensive either when compared to the HP one on a diesel.
Best of luck Dan.
Dom.
Post #76914 21st Aug 2011 8:21am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Dan, IIRC BBSSPY did a write-up on replacing the pump. Might be useful
Post #76927 21st Aug 2011 12:00pm
dan_uk_1984
Just been to cardiff and back - made sure I had over 1/4 of a tank the whole way and it was fine.
So either the pump is overheating OR the "jet pump" (which pumps from one side to the other) has failed.
Either way - I need a new pump. The whole thing is bought together; left pump, right pump and both senders. In total it's £170 so that's not bad. Probably £30 labour - so £200ish in total.
Looks like a mess of crap:
Post #76937 21st Aug 2011 1:11pm
on the bright side dan, you'd only be polishing it instead of getting to know it a bit better..
Post #76938 21st Aug 2011 1:15pm
dan_uk_1984
To be fair I polished & waxed it last weekend Razz
It's getting the engine bay cleaned sometime next week. If it makes it to work.
Post #76940 21st Aug 2011 1:25pm
dan_uk_1984
OK, now I think I've changed my mind on the pump overheating. I think that's just the RRS. I think one of the pickups is not working:
Fuel Tank by d86cfv, on Flickr
Whilst driving with 1/2 a tank of fuel the gauge shot up to 3/4, then back down after a few miles - somethings obviously not right here. I wonder whether one of the senders has gone wrong - or if one side of the pickup/sender unit has come off of its mountings.
It's at the garage today, I will report back with the results!
Post #77399 24th Aug 2011 8:22am
i wonder if it could be something as simple as a bad earth..
Post #77405 24th Aug 2011 9:15am
M44K TS
Lets's hope it's a straight forward fix mate. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #77418 24th Aug 2011 10:54am
jaybear
France
Dan
sorry to insist , but your car has been going through the same ordeals as my friends SC , ands the only definitive cure was changing the Fuse in the trunk's fuse box i already described to you ......
and a bad fuse could lead to the same symptoms as a bad earth .....
worth trying before buying the whole pump system !!!
Smile
jaybear Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #77421 24th Aug 2011 11:42am
dan_uk_1984
jaybear wrote:
Dan
Smile
jaybear
Already done - and the relay Smile
Post #77422 24th Aug 2011 11:50am
SteveMFr
Site Sponsor
Dan, you never answered - what about going back to the seller? (Just out of curiosity as you seem to be ruling it out)
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #77424 24th Aug 2011 11:55am
dan_uk_1984
Private sale Thumbs Up
Post #77425 24th Aug 2011 11:57am
jaybear
France
[/quote]
Already done - and the relay Smile[/quote]
So much for me then ... Did you check with the stealer if any soft update was available for your machibne ??? I remember the stealer said to my buddy that when serching for faults on his machine he did a whole batch of software updates which were not performed by the previous LR dealer .....
may also be of use to do that , even if not directlky related to your immediate concern ....
I just hope you find the issues for your truck , i know this can be quite frustraring ;
My buddy hads vbought his from an LR Dealer so even if it was 3 years old , he did take all the work and parts under the used car warranty , it helped for sure ....
Jaybear Jaybear
Post #77430 24th Aug 2011 12:44pm
dan_uk_1984
I'm not overly concerned - it's frustrating when it happens, but I'm relatively chilled about the whole thing. You cant own a RR and get upset everytime it lets you down!
It needs a SW update to make the 2nd-1st gearchange smoother as it's a little harsh at the mo. If there are any other SW patches to go on I will try and ensure these are done...
Post #77432 24th Aug 2011 1:14pm
Page 2 of 5 <12345>
