![]() | Home > Technical (L322) > Reduced Engine Performance - Fuel Pump |
Ok. This is getting tedious.
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
Are you sure there is actually enough fuel in the tank and the gauge is correct ? Far to many gone... |
Home now. Not too bad...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35618 ![]() ![]() |
bad luck on the 2 breakdowns dan, if it were possible to tow the range i'd come to your rescue... |
Teething troubles, all will be well soon |
Thanks guys.
As you may know, there are two pickups in the tank as it's split in two (complicated much!?), I suspect one has failed - this is why the car is dying at 1/8th.
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Wounder mate, lets hope you get it sorted asap. Nothing worse than a new motor playing up. 2006 Mercedes CLS
Always got the gaylander. Which in reality is a great little run around. 3.5V6, similar steptronic box and handles supprisingly well!
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
Dan
Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120 ![]() ![]() ![]() |
Dan
Dan, who did you buy the RR from - private party or dealer?
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
Dan,
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
I've done mine too. Although I did it without taking the seats out, it would have made life a lot easier. Mine was full of fuel so not pleasant.
