![]() | Home > In Car Electronics (L322) > I phone 4 connectivity bluetooth |
In which case, all you need is the Bluetooth ULF Module. If you search eBay for BMW Bluetooth ULF you will have plenty of results. Perhaps someone else on the forum can clarify exactly which ones will fit. But generally any from the early X5's will fit... http://www.ebay.co.uk/itm/GENUINE-BMW-BLUE...3f0d0752c6 ![]() |
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 ![]() ![]() |
Steve for my 2002 V8 , what they called première édition in france as it was loaded with everything , i have the OEM phone .. Will I need BMW ULF 84.21 6 934552 02 or 84.21 6-931854 01 ???? . Both are available today , one in Gy one is Austria and i don't know what to buy . your help will be appreciated ![]() 2002 V8 , premier edition , 19" alloys , |
Jaybear - neither of those part numbers is really good: the first is a 1st Gen ULF (really old) and will probably have connectivity issues with most modern phones and the second is not a normal ULF part#.
Hi Paul, The 'phone prep' is just a charging wire for the cradle that LR had avail back then (with like 4 phones to choose from... ![]() You'll likely need a new BT module (the touchscreen vehicles are different than the earlier models). There are threads on the Nokia BT module here in the forum. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Thanks a lot Steve
I couldn't find a pic on a quick search - basically just a female 54-pin connector and a male with a short bit of wiring in between. Re-pinning yields the same result for free. |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Hi Steve
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 ![]() ![]() ![]() |
Hello mate, I have a vogue with touch screen same as yours a phone prep no phone. However i do have bluetooth. Try putting your phones bt on and if your car has bt it will come up with "landrover" If it finds it. To connect the pin is 2121. Range rover td6 54 reg touch screen |
Does sound like you have a prob with the module communicating... Sorry, I don't have enough experience with the MOST system to help you further. ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
killatomato Member Since: 15 Jul 2011 Location: Wirral Posts: 41 ![]() ![]() ![]() |
Hi, I got my iPhone to connect to the built in Bluetooth, but it doesn't show contacts. My indie thinks I cannot update the software to show them. Is this true? Or will a stealer be able to update it? Mine is a 2005 touchscreen. |
I think there is an update re the phonebook showing - 1 hour download at stealers |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6779 ![]() ![]() ![]() |
Or an updated BT module form Wiggs (if he still has any) for £50 exchange ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
£60 exchange ..not £50 |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Hey guys - I;m sure I've asked before but need to do this now.
