Home > General > Problem with Aircon and Heated seats |
If the lights go out the system has detected a fault. It may be the ATC unit itself that has gone faulty.
19th Aug 2011 9:28pm |
andy vash Member Since: 15 Aug 2011 Location: uk Posts: 13 |
sorry for being stupid but whats an ATC unit ? |
19th Aug 2011 9:59pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
ATC = automatic temperature control... |
20th Aug 2011 8:43am |
I’ve had diagnostics run on the vehicle and it shows the air-con evaporator temperature sensor has failed and both heated seat temperature sensors have also failed
20th Aug 2011 1:14pm |
Mystery solved I now know why the heated seats don’t work; they’re not plugged in.
30th Aug 2011 6:39pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
there should be one big plug at the front "RANGEISM WILL NOT BE TOLERATED"
30th Aug 2011 6:50pm |
The wiring harness that power the seat motors are plugged into this big plug. i cannot see where the heated seat circuit plugs into |
30th Aug 2011 6:59pm |
there are only four nuts that hold the seat in, take the seat out and have a proper look.. |
30th Aug 2011 7:05pm |
what he said ..........there is a lot of boxs/modules under the passanger seat "RANGEISM WILL NOT BE TOLERATED"
30th Aug 2011 7:20pm |
