Home > Maintenance & Mods (L322) > How do test non return valve in remote oil filter housing ? |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Ad
19th Jul 2011 9:33pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
im getting this as well so any help on what needs changing would be gratfull as i was going to just change the vanos "RANGEISM WILL NOT BE TOLERATED"
19th Jul 2011 9:38pm |
is this the part you mean
19th Jul 2011 9:40pm |
Think thats on the vacum system that goes to the master break servo. Think Adam is after this http://www.ebay.co.uk/itm/Range-Rover-L322...646wt_1139 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
19th Jul 2011 9:51pm |
do you reckon that could be the problem with mine then as it only does it once in a blue moon and its for a second at the most "RANGEISM WILL NOT BE TOLERATED"
19th Jul 2011 10:30pm |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 |
Thanks Rob for that spot, I have decided to buy that filter housing as had priced one up last week and it was 200 pounds so grabed that one while I could. The car is going in next week for rocker cover gaskets, oil change (Mobil 1 5-40)and the old filter housing is getting tested and changed if needed.
20th Jul 2011 11:14pm |
thanks ill try that i dont suppose you have part numbers for that if not ill start hunting "RANGEISM WILL NOT BE TOLERATED"
21st Jul 2011 12:06am |
Just thought I would report back on my progress with my Noisey start up rattle.
6th Aug 2011 11:24pm |
well it looks as if this is what i need to do so thanks for the info "RANGEISM WILL NOT BE TOLERATED"
7th Aug 2011 3:03pm |
veyroncm Member Since: 19 Aug 2011 Location: Gerrards Cross Posts: 3 |
We had this problem on a BMW and 2004 Range Rover and replacing the Timing Chain Tensioner solved it on both cars. Its a 30 minute job and the part is about £45.00 Can never part with old friends even though they cost me a fortune to maintain. |
19th Aug 2011 11:15am |
On my first 4.4 I found that if the oil level was anywhere other than at the top of the marker then I would get the rattle.
19th Aug 2011 11:52am |
dan what oil would you reckomend for this time of year "RANGEISM WILL NOT BE TOLERATED"
19th Aug 2011 3:18pm |
The normal grade - i just go for a slightly thinner grade in winter. You could go for a grade thicker in the summer too. Only if you have a problem with loosing oil (thicker doesnt leak out or pass piston rings) If I ran winter grade oil in my P38 in the summer it would burn it... If I ran summer oil in winter it would clatter a lot. So i have generally followed the same principle with the L322... |
19th Aug 2011 3:27pm |
