![]() | Home > Maintenance & Mods (L322) > How do test non return valve in remote oil filter housing ? |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Ad
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
im getting this as well so any help on what needs changing would be gratfull as i was going to just change the vanos "RANGEISM WILL NOT BE TOLERATED"
is this the part you mean
Think thats on the vacum system that goes to the master break servo. Think Adam is after this http://www.ebay.co.uk/itm/Range-Rover-L322...646wt_1139 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
do you reckon that could be the problem with mine then as it only does it once in a blue moon and its for a second at the most "RANGEISM WILL NOT BE TOLERATED"
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
Thanks Rob for that spot, I have decided to buy that filter housing as had priced one up last week and it was 200 pounds so grabed that one while I could. The car is going in next week for rocker cover gaskets, oil change (Mobil 1 5-40)and the old filter housing is getting tested and changed if needed.
thanks ill try that i dont suppose you have part numbers for that if not ill start hunting "RANGEISM WILL NOT BE TOLERATED"
Just thought I would report back on my progress with my Noisey start up rattle.
well it looks as if this is what i need to do so thanks for the info |
veyroncm Member Since: 19 Aug 2011 Location: Gerrards Cross Posts: 3 ![]() ![]() |
We had this problem on a BMW and 2004 Range Rover and replacing the Timing Chain Tensioner solved it on both cars. Its a 30 minute job and the part is about £45.00 Can never part with old friends even though they cost me a fortune to maintain. |
On my first 4.4 I found that if the oil level was anywhere other than at the top of the marker then I would get the rattle.
dan what oil would you reckomend for this time of year "RANGEISM WILL NOT BE TOLERATED"
The normal grade - i just go for a slightly thinner grade in winter. You could go for a grade thicker in the summer too. Only if you have a problem with loosing oil (thicker doesnt leak out or pass piston rings) If I ran winter grade oil in my P38 in the summer it would burn it... If I ran summer oil in winter it would clatter a lot. So i have generally followed the same principle with the L322... ![]() |
