Home > Technical (L322) > Reduced Engine Performance |
Now that im a member of the sc club, my membership wouldn't be complete unless i was broken down on the M4 awaiting recovery!
16th Aug 2011 11:33pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
i hope you get it sorted and it turns out to be something simple and cheap "RANGEISM WILL NOT BE TOLERATED"
16th Aug 2011 11:59pm |
I'll see you in ASDA! |
17th Aug 2011 12:01am |
The RAC suck. I'm still here!
17th Aug 2011 12:37am |
have they showed up yet "RANGEISM WILL NOT BE TOLERATED"
17th Aug 2011 1:04am |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
Dan
17th Aug 2011 1:19am |
Just got home. drove off transporter perfectly with no messages. MIL remained on. Neither Rover all comms or my obdc reader want to read the code. 99% sure its the auxiliary coolant pump. |
17th Aug 2011 2:44am |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 |
Dan, Speak to Wiggs and get the Digital Tuner fitted. Then you can watch QVC on the hard shoulder next time.... Current MY2020 Gone: 1 x L405 and 2 x L322's |
17th Aug 2011 9:29am |
Yawn.
17th Aug 2011 2:31pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Hi Dan,
17th Aug 2011 3:48pm |
"Reduced Engine Performance" message on a SC RR is 99% caused by this. A large proportion of 2005-2007 SC RR's had the electric coolant pump wired the wrong way round, being a centrifugal pump it doesn't do it any favours running back-wards so leads to early failure. You can test your aux coolant pump by activating the "Rest Heating" function - Outside temp less than 15C, after turning off and taking key out of ign press "max ac", make sure after a few minutes the air coming out the vents is hot. If it's cool/cold then the pump doesn't work/is wired incorrectly. The fix is to correct the wiring (if your car is affected) and replace the pump if wired back-wards (even if it still works, it wont last much longer) |
17th Aug 2011 4:20pm |
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 |
As mentioned in many of my posts this has happened to me. Fairly simply job to replace when I did mine and no problems since. Just a shame I had. To find out myself as th garages didn't have a clue.
17th Aug 2011 7:49pm |
It's your posts that helped guide me to a resolution whilst sat on the M4, so thanks for taking the time to put the info on the forum. As long as this is resolved in mine tomorrow I might drop you a PM to arrange some sort of writeup for the WiKi if that's OK? It would be good to get the info in one place... Thanks, Dan |
17th Aug 2011 8:45pm |
