Home > Technical (L322) > EAS pressures and compressor stuff
Page 2 of 3 <123>
swast4
I'll try again
<img>
Post #76192 14th Aug 2011 4:01pm
swast4
And try again
Post #76193 14th Aug 2011 4:03pm
swast4
Bingo 3rd time lucky, her we go.
This shows piston with out ring fiteed.
This is piston liner
Piston ring
Piston ring
Piston Ring
Piston ring, There is a small pin on the radius of the piston that piston ring locates on, hence the funny shape, which also allows you to stretch the piston ring over the piston.
The thinest part of the piston
The fattest part of the piston or color
Piston ring
So from the pics we have dimensions of the liner and thickness of the ring, diameter of the piston, the tricky part is the bit that overlaps and keeps the piston ring wanting to touch the sides of the liner/cylinder.
Post #76195 14th Aug 2011 4:17pm
SteveMFr
Site Sponsor
It would def be interesting to get the dimensions on a new ring as a comparison.
Internally it looks very similar to the P38 compressor - except that the ring on the P38 compressor is a cup shaped bit that's much thinner than the split/expanding ring you have. It would be interesting to do a compression test on the compressor as well.
BTW, so the compressor is U-shaped with the motor forming one leg of the U and the cylinder the bottom part. So whats the black bit that's nearly as big as the motor that's the other leg of the U? And the funky valve at the end?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #76203 14th Aug 2011 4:53pm
swast4
The black bit the same length of motor is the air drier, basically a cylinder with silca gel inside, nothing complicated. there is a thicker pipe going back to the suction (spillback). There are 2 funky valves solenoids. One of them is a normally closed and open when motor is running (to stop system draining out and to enable compressor to be changed and I think the other one releases the air out of the system when lowing vehicle.
Adam
Post #76205 14th Aug 2011 5:19pm
Nice one ad. Just saved me a job! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #76220 14th Aug 2011 7:10pm
SteveMFr
Site Sponsor
Thanks Adam. That really demystifies things then. So the funky valves will be inlet/exhaust.
I've not had to work on the mechanical bits in my EAS yet after 3+ years of ownership - in contrast to the P38 where that joy didn't last 3 weeks (honest!).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #76248 14th Aug 2011 11:18pm
swast4
I've just given the compressor to our machine shop in work to see what he can do.
But looking at the dimensions in the photos I've got:-
36.24mm Cylinder Bore
26.46mm Small diamenter of piston
4.76mm Thickness of piston ring
37.45mm Diameter of piston ring with no tension on it.
So if the max diameter the ring can be fully compressed is 36.24mm and the existing diameter of the piston and ring is 35.98mm (26.46 x (2x4.76)) then there is only 0.26mm of wear, which doesn't appear to be alot ? The only other thing of any note is the edge of the ring is very slightly curved, but only very slightly.
The fact that the ring is slightly bigger than the bore should mean that it takes up the slack, but when the compressor and ring get hot ,would it contract and pull the ring into the closed position ?
Any thoughts ?
Post #76286 15th Aug 2011 12:40pm
SteveMFr
Site Sponsor
Any thoughts ?
Those were exactly the reasons I said that it would be interesting to have the dimensions of a new ring and to do a compression test.
If the ring is not what's causing the problems with your compressor then it has to be either inlet or outlet side. On the P38 compressors, the reed valves (if they are called that - 1-way inlet/outlet valves) have been know to fail. Air filter clear? Is the 'funky valve' switching properly?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #76424 16th Aug 2011 10:05am
swast4
Yeh I know what you mean but it means forking out £330 for an experiment. The inlet valve on the compressor looked fine with no damage or contamination. Also the inlet filter is just a round metal gause on the compressor. Not the funky witches hat tap thing.
Since I repaired my leaking d/c line my suspension is a bit faster moving between positions, I will see if I get the resevour filling fault again.
Adam
Post #76519 16th Aug 2011 9:26pm
SteveMFr
Site Sponsor
Hi Adam,
I know. Tis stupid. Sooner or later someone will get ahold of a new compressor and post the dimensions (prolly later tho - as only the fewest of schmucks will take apart a brand new compressor Mr. Green ).
If you have a compression gage in your toolbox, you could -theoretically - do a compression test. I'll try to find time to do something similar... Whistle
Sooner or later.
Steve
Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #76521 16th Aug 2011 9:42pm
swast4
Hi Steve,
The type of ring we have is apparently a split rider ring design, this is the funny overlaping type arrangement that you see. The piston itself has a small split pin on the side where the piston ring locates, to stop it spinning round the ring causing speedy wear. I have just been reading about 'split rider ring design' and read an interesting section as below:-
Do split rider rings need to be pegged to stop them turning
on the piston ?
It is important that split rider rings are stable on the piston and do
not spin, this however is normally achieved by the correct design
of pressure relief grooving but can also be achieved by pegging
the rider ring. This pegging also allows the rider ring to be turned
on the piston enabling its life to be effffectively doubled.
Interesting I thought, and might be worth taking compressor apart and turning over the ring. I have just bought a tired second hand compressor and might try it out. When I also got the bits to repair my holed d/c air line I picked up a 8mm OD 'T' piece and thought I may install it with a pressure guage and see it's performance along with tapping up Rob to monitor the Receiver pot pressures.
Adam
Post #76525 16th Aug 2011 10:12pm
That's interesting about flipping the ring over. If only we knew what a new one looked like. My old compressor had a radius on the ring. Have you stripped your old/new compressor yet Adam? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #76528 16th Aug 2011 10:57pm
swast4
Not got it yet, will experiment when I get it. That one of yours we havn't got a clue which way it was ? Is your cars stearing still good ?
Post #76530 16th Aug 2011 11:00pm
I took it off the first time I stripped it an never noted which way it was. We could test it both ways? Obviously work is busy then! Lol. Steering is amazing! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #76531 16th Aug 2011 11:08pm
Page 2 of 3 <123>
