Home > Technical (L322) > EAS pressures and compressor stuff |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Hi Guys
9th Aug 2011 6:36pm |
Cant answer your questions, but I too have looked at a dual pump system - came to decide it would be much more fun to make the later (more reliable and heavier duty pumps from 2006+) work in the earlier cars.
9th Aug 2011 7:18pm |
Cheers Dan. Any knowledge of the workings of the current system would be great. The new compressors sound good but sound expensive. Adam has picked up a 2nd heavy duty compressor for £25 which if we can get it to work is a cheaper system than £300 for a new pump. What controls are on the current compressor? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
9th Aug 2011 8:07pm |
I believe the L322 compressor has a temperature sensor on - in ye olden days it was just a thermal cut out switch.
9th Aug 2011 8:17pm |
Sounds like a second tandem system is the way to go. Let the logic do it's stuff on the old compressor and when it's req the second pump can help with the load using a relay system. A second tank sounds good but again expensive and complicated to plumb into the existing system. Plus I have LPG so space is a premium. Do you know anything about volumes from the reservoir or what volume the compressor can deliver don't want to plumb in a second compressor and it be under powered. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
9th Aug 2011 8:32pm |
The reservoir is bolted to the underside of the car, plenty of room for another. Again, just inline so the pressure switch on the original one does the work...
9th Aug 2011 8:35pm |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
I'd have to go back to find the exact specs on operating pressures - the system works at up to ~10bar. -Long Explanation Ahead- No official compressor refurb kits were ever available - you had to buy a new compressor (€800 here in Germany and France). The compressor is a dry running piston compressor - no oil - and has a teflon piston ring. P38's (and RRC's) had a very general wear pattern in the EAS: the air lines were 'plugged' into place with a sliding collet (the greater the pressure or pull on the air line, the more the 'fingers' of the collet squeezed the line) and sealed with rubber O-rings. After 5 or so years, the O-rings began to shrink and the lines leaked. The compressor worked overtime trying to keep the system pumped up. At some point, the teflon piston ring wore away and, in a worst case, the piston scraped and scored the cylinder bore. The EAS ECU noticed that the compressor was running for extreme lengths and the system was still low on air (or the compressor overheated) and the ECU decided it was time to shut everything down for safety's sake. This meant that the RR was dropped to the bump stops and 'EAS Fault - Max 35 MPH' was displayed in the cluster. The only way to clear the faults was the dealer Testbook diagnostic tool or later the Autologic or Rovacom systems at independent garages ~€100 (this lead to the development of the free EAS Unlock Suite and, in effect, our present system as well (3rd post down and later posts in the thread)). The dealer's solution was: - a new valve block (as the O-rings were not considered dealer replaceable) €800 - a new compressor €800 - fault reset with the Testbook - labor All in all somewhere in the vicinity of €2200-€2500. Crafty P38 owners (me, for instance ) discovered that the O-rings were standard items that could be purchased at any industrial supply specialist for about €1.50 and even craftier P38 owners started making compressor piston rings. These compressor ring makers (I believe amongst the first was the Goswin from http://www.landroverwinkel.nl/ ) then got complaints from people who had installed the teflon rings on compressors with badly scored cylinders and the problem reappeared within a few days. So they started making replacement cylinders as well. That's a very comprehensive summary P38 compressor probs and of why there are replacement compressor piston rings. Why do they not exist for the L322? I've never taken a L322 compressor apart - I don't know how difficult or easy it is and what the seal looks like (if you have please post pics!!). But if it is not too difficult to get to I'd surmise the following: - these developments for the P38 took place from around 2005 on when the series was 10yrs old, the demand had grown enough, and P38 prices dropped to the point where people who didn't have €2500 to spend every time the car was in for service were purchasing them. We're just getting to that point with the L322. - LR dropped the O-ring/collet arrangement in favor of a much more reliable flange nut/flared tube system - compressor prices aren't quite as ridiculous for the L322 - the L322 doesn't drop to the bump stops at every EAS hiccup TBH, I don't really see much point in a 2nd compressor. If the EAS isn't leaking and the compressor seal is OK it should last a good long time. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
10th Aug 2011 10:43am |
Does there need to be a point? |
10th Aug 2011 10:47am |
10th Aug 2011 11:10am |
That's some good info. Thanks. Nice to know the fix for our compressors should be as simple as a pistonring. Adam will post those pics you sent me when I get home tonight. If the compressor is still stripped can you remeasure the ring fully compressed? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
14th Aug 2011 12:17pm |
oh - then ignore my reply in the other thread...
14th Aug 2011 12:53pm |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 |
Will do Rob. What othe rthread Steve ? |
14th Aug 2011 2:10pm |
http://www.fullfatrr.com/forum/topic7045.html
14th Aug 2011 2:13pm |
Ok got that - No probs.
14th Aug 2011 3:00pm |
