Home > Maintenance & Mods (L322) > Front Bushes - Covered by LR Warranty?
rich_959
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi everyone,
I'm 3 months into FFRR ownership (and 3 months into the 12 month warranty) and have noticed the development of a knocking on the front when going over light bumps at low speeds - in my very limited knowledge, it sounds like a worn bushing or something along those lines. It's an 07 TDV8 with 40k miles.
If it turns out to be bushes, do you think it will be covered by the warranty, or is it classed as wear & tear? The reason I ask, is that I don't want to take it in and get stung for 'investagative' work to then be told it's not covered, because I'd rather just have my local specialist do the work in that case. Any clues/experience of this?
Cheers folks!
Post #76446 16th Aug 2011 11:13am
Anti-roll bar link worn.
Cheap to replace almost certainly not covered by warranty, but worth a try.
Post #76454 16th Aug 2011 11:40am
rich_959
Cheers - I did read several posts which seem to point to the ARB links as the likely candidate, just wondered if anyone else had been succesful at getting it done under warranty. I'll have to go and see what they say....
Thanks for the reply!
Post #76458 16th Aug 2011 11:49am
