Home > Off Roading & Green Laning > Wading in an FFRR |
I keep seeing cheap bonnets pop up on the bay and am thinking of buying a damaged one so that it can be cut to allow an RAI.
15th Aug 2011 6:49am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
myself, mzplcg , justinp and a bunch of disco3 blokes went through some fords down nr salisbury and these must have been about 2 1/2 to 3 foot deep , enough to get a decent bow wave and we had no problems at all.. |
15th Aug 2011 7:48am |
The wading depth on the RR is either 50cm or 70cm depending on what year you have. Anything more than this and the outside water pressure on the door seals etc will be significant and may start to ingress.
15th Aug 2011 7:57am |
Was that to the top of the arches then or over the bonnet?
15th Aug 2011 7:58am |
ah so the lights will go pop, i take it the ballasts are the bits that will go as i thought the lights would be well sealed??
15th Aug 2011 8:04am |
it got a little bit deeper further on.. |
15th Aug 2011 8:40am |
Don't forget spare underwear! |
15th Aug 2011 8:52am |
azure111s Member Since: 28 Apr 2011 Location: Wiltshire Posts: 71 |
Where's the ford? I'm sure I've been through it but a long time ago - probably in 1996 in my old 300TDi Disco'. Trouble is, I can't remember where it is!! |
16th Aug 2011 8:28am |
not sure mate , we were in convoy and i just followed the car in front..pretty sure it was near winterbourne dauntsey somewhere... |
16th Aug 2011 8:34am |
You're right - thanks! 'Ere tis......
16th Aug 2011 8:51am |
links dead ..
16th Aug 2011 8:53am |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Any idea what they changed to increase the wading height by 20cm, and what year did the change occur? Gone - Range Rover Supercharged 2006 |
16th Aug 2011 10:35am |
Very true, thats why i was thinking of doing the home based method, some nice big soft rubber gaskets and some silicone where needed after some pressure testing... Still grille hieght on the picture looks deep enough i reckon! |
16th Aug 2011 10:49am |
You don't need a new bonnet. The TD6 draws air through the RH side vents. The easiest would be making a blanking plate fort the side vent and running a snorkel fitted to the side (poss RRSport?). Then you'd need a tube of some sort (as Dan says, must be big enough) through the wing to the air filter intake. And you'd have to make sure all is water tight.
16th Aug 2011 11:12am |
