Home > Technical (L322) > Removing scrivets from the A-pillar (both sides)
pdt
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi all
this might be a dumb question, but here we go...
How do you remove the scrivets from the A pillar? (there are 4 of them holding the external sill cover on).
They do not have a philips or flat head on them...
Is there a trick?
I am replacing both front sill covers due to the left one being loose.
Any help/thoughts always appreciated.
Cheers
pdt
Post #76108 13th Aug 2011 8:09pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
You have to drill them out and buy new ones. This is the case when your windscreen is replaced. Ring the part department and ask for an a pillar cover fixing kit. You should get replacement plastic rivets and the plastic inserts for the holes in the body shell.
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #76118 13th Aug 2011 9:52pm
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
You can drill them out, you can drill a pilot hole and thread a fine screw and pull them out or ... as I do, with a punch, just knock the centre through (the centre just falls to the bottom of the A-Pillar) and they then just pull off!
Post #76268 15th Aug 2011 8:02am
SteveMFr
Site Sponsor
Ahhh, a quality stickler. I know how that is. Razz Nearly everyone else I've ever dealt with just punches them through.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #76466 16th Aug 2011 12:07pm
