Home > Technical (L322) > Wiring location for Rear PDC
pdt
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi guys
Had a few problems with PDC of late and did the check and worked out that the middle offside rear was not working. Thought - I will get around to that.
I was under my S/C RR today doing some routine stuff and found that a section of wiring had dropped from under the bumper on the offside and ... down onto the exhaust! Some nice melting of cables going on....
So, I am now wondering, is this the loom for the rear PDC?
The exhaust has made a good ol mess of it too!
Thoughts, suggestions and anyone localish that could fix (west london).
Cheers
pdt
Post #75026 6th Aug 2011 12:52pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I have replaced my rear bumper and the only wire there was for the parking sensors.
Removing and re-fitting the rear bumper is an easy job, bodge it first with some spare wire and see if it solves your issue. 2004 black Vogue TD6
Post #75041 6th Aug 2011 4:07pm
pdt
Yep - spot on.
That was it.
Dan at Duckworth parts has got a new loom for me.
Here comes a bit of fun removing the bumper.
Anyone got a how to?
Cheers
pdt
Post #75278 8th Aug 2011 7:42pm
letsavit2
its really not hard mate, download rave it tells you where all the bolts are, some are under the plastic trim on the bumper top and there are some clips to the sides, at the top. Other than that its standard blots you can see.
Put down an old blacket when taking it off to protect your paint, as you obviously cant walk off with it due to the wire.
oh and make sure this time all the wire is in the clips.... Wink 2004 black Vogue TD6
Post #75291 8th Aug 2011 9:29pm
