Home > General > tyres |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
just replace the ones which are worn....dont listen to the garage ,they are only trying to make money out of you... |
29th Jul 2011 3:59pm |
rory_mcw Member Since: 08 Apr 2009 Location: Angus - Scotland Posts: 113 |
on all of my 4wd cars i have always changed the 4 at the same time. |
29th Jul 2011 4:14pm |
On a couple of occasions I have only replaced either the two fronts or two rears as there has been no need to change all four if only two are worn down |
29th Jul 2011 4:18pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
The only time it is essential on a 4x4 to have tyres with matching tread wear front and back is if a diff lock is used between front and rear axles. Imagine if one axle had tyres half and inch smaller in diameter than the other axle. Both sets of wheels would be rotating at the same speed but the more worn tyres would be covering a shorter distance with each rotation. This would result in tyres scuffing badly or excess strain on the drivetrain etc.
30th Jul 2011 12:48am |
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 |
many thanks fo rhte replies- will replace just the fronts for now then! |
1st Aug 2011 8:57am |
