![]() | Home > Technical (L322) > Noise And Vibration - Help! |
rangie1235 Member Since: 29 Jul 2011 Location: Cheshire Posts: 4 ![]() ![]() ![]() |
Hi All, New to forum, Have got 2006 vogue TD6, It has started making a strange noise before the engine gets up to normal temp. The noise and vibration occur when setting off from a standing start from inside the vehicle it sounds and feels as though its coming from under my feet its audible above radio on normal volume take your foot of the accelerator and it stops does not make noise in neutral, once the engine is warm the problem reduces by 95% had it in the garage and they have checked all they could and suggested wait till it gets worse then we will be able to work out what it is!! any ideas any one ?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
welcome to the forum..
Thanks, did not think of that been fearing the worst! will get it checked..... |
not saying it is that but check it out first..with you saying it stops when in neutral, it could be the gearbox, hopefully its not . |
You give him sleepless nights saying it might be the gearbox Stan is that how you got the label "SCAREY" |
Not me |
its close isn't it ... satan , now that's a good user name... |
Not me |
getting slightly |
Thanks for scaring me with the gearbox ! Cat sounds promising going to check it out over the weekend will let you know how I get on ... |
update, the strange noise and viubration turned out to be a stone trapped between the car and a heta shield, took a long time to find feared the worst more than once! all good now stone removed... |
