Home > Technical (L322) > Noise And Vibration - Help!
rangie1235
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi All, New to forum, Have got 2006 vogue TD6, It has started making a strange noise before the engine gets up to normal temp. The noise and vibration occur when setting off from a standing start from inside the vehicle it sounds and feels as though its coming from under my feet its audible above radio on normal volume take your foot of the accelerator and it stops does not make noise in neutral, once the engine is warm the problem reduces by 95% had it in the garage and they have checked all they could and suggested wait till it gets worse then we will be able to work out what it is!! any ideas any one ??
Post #74149 29th Jul 2011 2:42pm
welcome to the forum..
the only thing i can think of is that the cat in the exhaust might be loose causing the noise and when it warms up it expands and stops vibrating..
Post #74151 29th Jul 2011 2:50pm
rangie1235
Thanks, did not think of that been fearing the worst! will get it checked.....
Post #74152 29th Jul 2011 2:54pm
not saying it is that but check it out first..with you saying it stops when in neutral, it could be the gearbox, hopefully its not .
Post #74153 29th Jul 2011 2:59pm
You give him sleepless nights saying it might be the gearbox Stan is that how you got the label "SCAREY" Laughing
Post #74156 29th Jul 2011 3:10pm
Laughing
its very difficult to diagnose something like this unless you are actually with the vehicle..might have to change my user name to something like 'fluffy' or maybe just 'stan'.. Wink
Post #74157 29th Jul 2011 3:20pm
Not me
Post #74159 29th Jul 2011 3:22pm
its close isn't it ... satan , now that's a good user name...
Post #74162 29th Jul 2011 3:31pm
Not me Ner Ner Ner Ner
Post #74164 29th Jul 2011 3:36pm
getting slightly Off Topic here.. Laughing
Post #74166 29th Jul 2011 3:47pm
rangie1235
Thanks for scaring me with the gearbox ! Cat sounds promising going to check it out over the weekend will let you know how I get on ...
Post #74184 29th Jul 2011 5:44pm
J.Seven
Portugal 2003 Range Rover Vogue Td6 Monte Carlo Blue
Any update? J.Seven
Post #80071 9th Sep 2011 1:59pm
rangie1235
update, the strange noise and viubration turned out to be a stone trapped between the car and a heta shield, took a long time to find feared the worst more than once! all good now stone removed...
Post #80441 11th Sep 2011 5:08pm
