![]() | Home > General > 20" tyre pressures ?? |
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 ![]() ![]() ![]() |
Correct tire pressure measurements should be found on the sticker on the drivers door. In what way do you find filling tires with nitrogen better then filling with normal air? '01 1.8i Freelander. Grey/ grey
Marksman Member Since: 24 Dec 2010 Location: Durham Posts: 73 ![]() ![]() ![]() |
I find that the pressures are maintained for far longer (up to 6 months) without having to keep topping up, I believe the tyres last longer as the temperature / pressures are less variable. These are at 22000 as still plenty life left |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
Speaking as a chemist, I would expect air to maintain a more constant pressure versus nitrogen.
now this is interesting! my 20' Continentals are wearing out on the sides, even though I regularly balance them, swap them around and use the car rarely within the first year of ownership! I think its time to try nitrogen! '01 1.8i Freelander. Grey/ grey
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
nitrogen wont help..wheel alignment will.. |
Maybe but worn shoulders is a known problem with the Continentals . 2008 MY Supercharged
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6744 ![]() ![]() ![]() |
Does nitrogen make the car lighter? |
Are there any better tires out there? since 20' Conti's come as standard equipment for the S/C... '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
