Home > Maintenance & Mods (L322) > Machine polishing tips do's donts etc .
Googsy
Guys
I have a few tiny superficial scratches on my car but also some paint chips i have overfilled with touch up which look naff . Also the usual swirls were the previous owner used a carwash Evil or Very Mad I would like to maybe get the car machine polished to smooth these over . Would welcome any tips on I can approve the appearance to rather than bringing to the Pros .
Cheers
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #73148 20th Jul 2011 8:58pm
Andy D
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
Hi googsy,
Take a trip over to www.detailingworld.co.uk
There's more info on their site than you can shake a stick at '07 Supercharged in black with drug dealer tinted windows
Post #73151 20th Jul 2011 9:16pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
Hi googsy
detailingworld is a great site. I'm also Member there.
I can recommend this guide: http://www.detailingworld.co.uk/forum/showthread.php?t=66024
It covers everything what you need to know about machine polishing.
For the swirls I use Swivax/Swizoil Cleaner Fluid Medium with a medium abrasive Pad. (3M Pads are great)
If you used touch up paint you may have to sand it down to the same paint level as the rest of the car.
Use some wet sand paper (3000grit and higher) and polish it after.( more infos about that are also on DW)
Cheers
Phil
P.S. Polishing a Range Rover is a lot of work!!! But the result is awesome.
Post #73188 21st Jul 2011 8:45am
HUGI wrote:
Hi googsy
Cheers
Phil
Great link Hugi, its got me all enthusiastic too Very Happy .
Post #73194 21st Jul 2011 9:34am
Googsy
Thanks guys i wont leave site now unlike some Laughing much appreciated . Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #73235 21st Jul 2011 12:21pm
I had some enthusiasm until I started one hot day and realised how Censored big they are and how much surface area there is to cover.
Oh and unless you're about 6'5" get a set of stepladders for the roof! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #73249 21st Jul 2011 1:45pm
mzplcg
Yeah, proper steps too. Don't do what I did in this thread
http://www.detailingworld.co.uk/forum/showthread.php?t=65875
Dom.
Post #73252 21st Jul 2011 2:06pm
Oops! Rolling with laughter Got - 2017 SDV8 Autobiography in Loire Blue
Post #73256 21st Jul 2011 2:17pm
Also many be worth visiting the Meguairs Youtube channel - loads of videos / howtos etc
http://www.youtube.com/user/MeguiarsUSA .
Post #73261 21st Jul 2011 3:28pm
Googsy
Right had a go at the chips using the following mehod:
Mixed Java black with clear laquer about 4 to 1 .
Applied in a blob
Then removed excess after 24 hours using a blade
Used 2000 Grit ( lowest I could get and used fairy liquid and water as a lubricant)
Worked out fairly well but I seem to have been a bit too agressive and i seem to have gone through to the undercoat Big Cry Big Cry
Its on the top of the boot lid were it says Range Rover I might give it another go its not a huge spot but there none the less . I have managed to put an IRL sticker to cover one spot and used some touch up on the other.
Im thinking it might be a good idea to have the top part of boot lid resprayed now as there are other minor scratches and think it could easily be blended given its only a small area
All suggestions welcome will try and take a pic later ...... Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #73484 23rd Jul 2011 1:36pm
HUGI
Applied in a blob
2000 grit was really too much. Even 3000 grit is very powerful! I use normally a 4000 grit and polish it with heavy compound.
Post a pic here and also at DW I'm sure we can help you to get it fixed. Scratches normally dont need a respray. If they arent to deep you can polish them out with a rotary polisher and some good polish.
Post #73486 23rd Jul 2011 2:18pm
Googsy
Thanks Hugi all I could get was 2000 grit it actually looks worse than it is in picture. As can be seen I have blobbed paint over spots for the time being until I can get 4000 grit or so.
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #73497 23rd Jul 2011 6:11pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
thats a mess, get a pro to sort it. 2004 black Vogue TD6
Post #73532 23rd Jul 2011 10:38pm
Googsy
Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #73533 23rd Jul 2011 11:15pm
HUGI
Ask on DW for Help. Maybe there is a member in your region who is willing to help.
From the pictures I would say:
Tape the area where you want to correct it (use 3m Automobil tape) then sand the blobs with 4000grit WET!! (let the paper soak in the water for an hour) and dont sand too much. After that use some 3m polish compound (i think the green is the strongest) then the yellow and in the end the finishing polish (which should be blue) Then add some protection (Wax or sealant)
(this is only a proposition I would do it like that but if you are not experienced with polishing (rotary polisher) so I would advise to correct it with someone who knows how to do it)
Good luck!
Post #73541 24th Jul 2011 8:00am
