Home > Off Topic > exhaust jack
exhaust jack
its well known that the scissor jack supplied with the range is pants so i'm thinking what are the alternatives ..
trolley jacks or bottle jacks can be awkward to carry in the back of the range , so what about exhaust jacks...any one used one on their range or has experience of them.
link to one on amazon priced competitively at £50 delivered.. http://www.amazon.co.uk/CONRAD-30178-BlowU...sbs_auto_1
Post #73088 20th Jul 2011 10:03am
Would the thing actually blow up when fixed to an exhaust with two outlets?.
Or is the rear silencer split into two internally.
Post #73089 20th Jul 2011 10:40am
you have two options, plug the end into one of your exhausts and bung the other side up or, use a cheap air-compressor from asda for instance [£6]..the air compressor apparently keeps the air jack cleaner than the exhaust option..
Post #73090 20th Jul 2011 10:52am
Googsy
There was a good few posts on these on the Disco3 Forum searching there might be useful. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #73093 20th Jul 2011 11:14am
I wouldn't use the exhaust as the back pressure could cause unforseen issues with sensors and cats and such forth. Cheap air pump is the better option. IIRC some Firecrews in some countries use these to help with access and such like..
Post #73095 20th Jul 2011 11:28am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
scarey, that air jack is just plain scary! EDIT - "boxed product weight 2.7kg" Shocked what is it made of? carrier bags?
if you jack up your RR with that it will pop and hurt you.
have a search on D3 like Googsy says. The guys did a lot of research
Get the real deal:
http://www.takla.co.za/prod03.htm (strongest) (weight about 10kg, by the way!) made of strong stuff
http://www.frontrunner.co.za/fr_products/products/fraircrane.php (will do the job, but a bit lightweight)
Post #73097 20th Jul 2011 11:42am
Fox
Not a fan of exhaust jacks.
Can't you fit a bottle jack in the cargo bit under the boot floor? (where the demountable tow bar should go)
Post #73098 20th Jul 2011 11:45am
@baben..the more i read ,the more i think its a bad idea...for off road use maybe but i cant see the benefits for day to day use.
@fox...thats what i got at the moment, and the crappy scissor jack so with them and the breakdown service i should be ok.. Thumbs Up
Post #73103 20th Jul 2011 1:24pm
PJS
Id probably go for this and an air compressor. Could imagine it popping though Rolling Eyes
Post #73110 20th Jul 2011 2:52pm
Baben
I would only recommend an airjack for Offroad and recovery use. On-road you have better options like a decent bottle jack with some means of interfacing with the vehicle
Post #73120 20th Jul 2011 3:18pm
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
fox will tell you that the camel trophy used these on there events around the world Whistle ONE LIFE LIVE IT
Post #73470 23rd Jul 2011 8:55am
