Home > Off Topic > exhaust jack |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
its well known that the scissor jack supplied with the range is pants so i'm thinking what are the alternatives ..
20th Jul 2011 10:03am |
you have two options, plug the end into one of your exhausts and bung the other side up or, use a cheap air-compressor from asda for instance [£6]..the air compressor apparently keeps the air jack cleaner than the exhaust option.. |
20th Jul 2011 10:52am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
There was a good few posts on these on the Disco3 Forum searching there might be useful. Present :2008 TDV8 HSE
20th Jul 2011 11:14am |
I wouldn't use the exhaust as the back pressure could cause unforseen issues with sensors and cats and such forth. Cheap air pump is the better option. IIRC some Firecrews in some countries use these to help with access and such like.. |
20th Jul 2011 11:28am |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 |
scarey, that air jack is just plain scary! EDIT - "boxed product weight 2.7kg" what is it made of? carrier bags?
20th Jul 2011 11:42am |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Not a fan of exhaust jacks.
20th Jul 2011 11:45am |
@baben..the more i read ,the more i think its a bad idea...for off road use maybe but i cant see the benefits for day to day use.
20th Jul 2011 1:24pm |
PJS Member Since: 06 Jul 2010 Location: Yorkshire Posts: 506 |
Id probably go for this and an air compressor. Could imagine it popping though |
20th Jul 2011 2:52pm |
I would only recommend an airjack for Offroad and recovery use. On-road you have better options like a decent bottle jack with some means of interfacing with the vehicle |
20th Jul 2011 3:18pm |
igore Member Since: 20 Oct 2010 Location: portsmouth Posts: 118 |
fox will tell you that the camel trophy used these on there events around the world ONE LIFE LIVE IT |
23rd Jul 2011 8:55am |
