Home > Maintenance & Mods (L322) > 2005 4.4.V8 Transmission Service
f4rrs
Hi,
I have a 2005 Petrol 4.4 V8 (Jaguar Engine) and its about to turn a 100,000 miles and i would like to have the gearbox serviced and in two minds as to what to do.
My options are as follows
1) power flush to remove and change 97% of the ATF Fluid
2) Change the filter and clean the magnets and refill with approx 6 litres of ATF (approx 50%) at my local LR Specialist
Your thoughts on the above would really be appreciated as i can't make my mind up as to which way to go on this.....
Many Thanks in advance
Post #71521 7th Jul 2011 10:59am
But 20 litres af ATF change the filter and triple flush Thumbs Up
Post #71540 7th Jul 2011 1:23pm
pretlove
i thought that was a bmw engine "RANGEISM WILL NOT BE TOLERATED"
Post #71549 7th Jul 2011 2:07pm
f4rrs
No its the first of the Jaguar based engines...
I've had a really big service with additional works to include the spark plugs and transfer box oil changed.
Changing the air filter has made a huge difference as it was really badly clogged up
Just the gearbox know needs attention as it can be a little clonky at times
Post #71559 7th Jul 2011 3:36pm
I changed my filter and ATF last year, I'm going to do another double flush in the next month or so for complete piece of mind
Post #71567 7th Jul 2011 4:57pm
f4rrs
Can i ask you Did you feel the difference?
i.e was it smoother and quieter and did it eliminate any clonky gear changes?
Many Thanks Mate
Post #71569 7th Jul 2011 5:09pm
Can't answer you on that one, I didn't have any issues with my box to start with, but I do like preventative maintenance hence the oil flush this year again
Post #71573 7th Jul 2011 5:14pm
pretlove
i need to do mine just trying to source the parts for a reasonable price first "RANGEISM WILL NOT BE TOLERATED"
Post #71615 7th Jul 2011 6:59pm
f4rrs
Just thought i'd post an update on this.........
Transmission oil and filter changed last Thursday at Heywoods. I inspected the magnets held in the pan and they were very clean.
In hindsight i would have had a powerflush and had 97% of the oil changed.
I am monitoring my average mpg at the moment because it seems to have vastly improved. I will let you know if this changes.
Post #72828 18th Jul 2011 4:16pm
