Home > Technical (L322) > Venture Cam
Neil E
2019 Range Rover 2.0 PHEV Mariana Black
Venture Cam
Only used the venture cam about 2 or 3 times and that was to only check it worked about 12-18mths ago.
Now we`ve a baby due (or actually over-due!) I was going to use it as a baby monitor when driving.
Fitted the baby seat in tonight, took the cam out of the cradle and now the fr**ing thing doesn`t come up on the front screen!
The green light is on as if it`s charged. Pressing the button again puts the red torch lights on but still nothing??
I`ve done a search on the forum for the past hour but can`t seem to find any advice.
Any suggestions?
Thanks
Neil MY21 P400e AB
MY10 3.6 TD V8 Autobiography
55 Vogue se
Post #71916 10th Jul 2011 8:49pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Try deleting the camera from the menu, then put it back into the cradle to reattach it.
Gone - Range Rover Supercharged 2006
Post #71918 10th Jul 2011 8:52pm
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
But it wont work whilst driving... Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #71984 11th Jul 2011 1:17pm
JustinP
Mine works fine whilst driving.
Post #71987 11th Jul 2011 1:19pm
Neil E
I`ve not had chance to delete and re-fit it yet, but I thought the venture cam was designed to be used for driving over rough terrain. Enabling the driver to see the ground ahead before he goes over it?? MY21 P400e AB
55 Vogue se
Post #71995 11th Jul 2011 2:37pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
use mine all the time while driving with horses [bit different to children]
Post #72016 11th Jul 2011 5:22pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
Can 't be used at the same time as handsfree though Sad
Post #72020 11th Jul 2011 5:31pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Go to 4x4 info, and hit the venturecam button, simple as that. If you don't have a venturecam paired, just switch it on and the system will see it. Works while driving for sure
Post #72032 11th Jul 2011 6:12pm
Neil E
Tried deleting and re-installing the venture cam but it`s still not showing, any other ideas??
Crying or Very sad MY21 P400e AB
55 Vogue se
Post #72604 15th Jul 2011 7:43pm
Baben
I had some tribulations pairing a second camera that I was given. It just didn't work and I started to suspect it was a different spec or something. I deleted the original, left the car to sleep for 20 minutes, then started her up and switched on the cam, and it paired after about 20 seconds, repeated for the second one. They are a bit finicky.
Make sure you switch off the bluetooth on your phone and any phones that are paired to the car during this process, as Avi says, it uses a similar frequency to bluetooth, and the car will only allow one or the other to operate at one time.
Post #72620 16th Jul 2011 4:48am
