Niiiice! Thanks David! With your description I was able to figure it out! Too bad GAP doesn’t have an option to lock axis cause it’s still kinda fiddly.
Anyway for anyone wondering the same thing:
- once you tap either of the axis on the left or tap the bottom left description (engine speed, turbine speed) — tapping these cycles graph selection
- the graph will then be bold, to up/down on the vertical axis just slide up and down
- to change axis scale (rpm scaling in this case) pinch and zoom VERTICALLY
- if you want to change the time scale pinch and zoom horizontally
So, with that said, looking at my transmission graph for 39 seconds, I believe my solenoids are fine, what say you? @dhallworth and @rrphil
Transmission engine speed kinda steps but I see that in David’s graph too, so maybe it just doesn’t report as often?
R 2011 Range Rover L322 SC - Autobiography (Ipanema Sand)
Ontario, Canada
