Home > Technical (L322) > 6HP28 Possibly Juddering |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
Hmmm. They’ve sent you the 1068 298 047 solenoid kit for the E-shift 6HP28. I wonder why they’ve done that? They must know you have the M-shift version because you ordered the 063 intermediate sheet. Strange.
15th Dec 2023 2:49pm |
15th Dec 2023 3:04pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3108 |
Another question I’m afraid, Phil.
15th Dec 2023 8:31pm |
I don’t think I’ve ever seen any documentation regarding the tightening sequence for the 17-off M5 x 40 screws which hold the two valve bodies together, plus the 5-off M5 x 55 screws which bolt the electronic module to the hydraulic module.
16th Dec 2023 12:13am |
For the sake of completeness, this is the tightening order for the screws which bolt the Mechatronic unit into the casing. Yours will be the later 13 screw design (i.e. 10-off M6 x 59 plus 3-off M6 x 20):
16th Dec 2023 5:32pm |
Thanks Phil. Really appreciate you posting those diagrams.
18th Dec 2023 1:55am |
All dampers replaced along with the intermediate plate and all solenoids.
27th Dec 2023 9:06pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1773 |
My 1st-2nd gear change when cold isn't as smooth as I'd like it to be. And the sump is leaking
28th Dec 2023 9:20am |
toronnoRR Member Since: 26 Feb 2024 Location: toronto Posts: 15 |
Hi Dhall,
24th May 2024 3:40am |
It’s perfect
24th May 2024 6:52am |
