Home > Maintenance & Mods (L405) > front control arms
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
fisha wrote:
Good job. I think this is a job thats creeping up on me in the near future. Knowing my luck, I'll probably find it a pain like you did.
i think i may of caused some of the problem myself as i removed both of the control arms at once (still new to range rovers ) so i think if you only remove one at a time you wont have as much trouble as me ,going to be doing the other side in the next few days so will let you know
Post #716786 25th Apr 2025 7:02pm
will308f
Did mean to ask to those who have replaced there control arms did you use new bolts ? I didn’t but have got new nuts on order as they got trashed getting them off
Thanks
Post #716809 26th Apr 2025 6:48am
will308f
ok just finished the other side this time i did one control arm at a time still a faff but didnt get the same issue as i did on the other side Thumbs Up
just been for a drive around and i have to say at the mo its a bit creaky but im hoping it will go away as it settles he says with fingers crossed Laughing
Post #716983 28th Apr 2025 2:51pm
kevinp
Did you remember to tighten the bolts with the weight of the car on the ground and not in the air. Shouldn't creak really.
Post #717001 28th Apr 2025 5:20pm
will308f
i jacked up the hub to normal ride height was this no good ?
Post #717004 28th Apr 2025 6:02pm
Gremlin500
Yes, that’s OK, as far as the car is concerned it’s at normal ride hight.
It’s to prevent torsion (twisting) of the rubber bushing being pre-tensioned by the weight of the car, causing the bush to fail early. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #717008 28th Apr 2025 7:06pm
will308f
ok right got something correct then lol
Post #717009 28th Apr 2025 7:07pm
