Home > Maintenance & Mods (L405) > front control arms
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
front control arms
hi
started to replace my front control arms a couple of hours to get them off replaced the front lower arm a bit of a faff but ok moved one to the upper arm wtf could not get it to fit if i put the inner bolt in couldnt get the ball joint in if i put the ball joint in couldnt get the inner bolt in Censored Censored Censored checked new part with old part the same im at a loss Big Cry Big Cry
Post #716663 23rd Apr 2025 7:30pm
Gremlin500
You can do this! Don’t admit defeat! Evil or Very Mad
Ball joint in first, but put a big cable tie through the front hole & bracket to take the weight & keep the front bushing in roughly the right place and take the weight off. Then you need to use a small trolley jack/wood blocks to support/lift the arm, vs a short pry bar (curved end) to push the donut either downwards or backwards to get it roughly in position, before using the pointy end of the bar to line up the two holes (bracket & donut) It’s essential to use a good light and a MIRROR to see what you’re doing, as if the holes aren’t lined up properly, you just won’t get the bolts in. Without the mirror, you won’t succeed.
Go for it man! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #716666 23rd Apr 2025 8:30pm
Gremlin500
Ooooops! Sorry, I misread your spelling mistake, Lower Arms done OK, but struggling with UPPER arms, is that right? Embarassed “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #716667 23rd Apr 2025 8:34pm
fisha
Try jacking up the hub so it’s sitting at a normal(ish) ride height rather than hanging in the air. Sometimes the limit of travel is the ball joint , and when removed, the arms move beyond the ball joint limit so you’d never be able to put the ball joint back in. Holding the suspension at a more normal height allows more flex at the ball joint. V8 or else ...
Post #716674 23rd Apr 2025 8:56pm
will308f
yea thats it done the one you show was a faff but done Thumbs Up
its the upper what a right pain Censored just ordered a ratchet strap (screwfix) so will try and pull the hub in with that ......the thing is that i have the other side to do as well Laughing Laughing Laughing Laughing Laughing
i do love my range rover but sometimes just sometimes it drives me mad Big Cry
Post #716689 24th Apr 2025 7:09am
will308f
@fisha yes done that also let the air out the bag so not fighting against that as well
Post #716690 24th Apr 2025 7:11am
fisha
Than all thats left to suggest is LR tool #1:
Whistle V8 or else ...
Post #716697 24th Apr 2025 8:15am
will308f
Rolling with laughter Rolling with laughter Rolling with laughter
Post #716708 24th Apr 2025 10:29am
will308f
day 2 and still no closer Big Cry Big Cry Censored Censored Censored
Post #716725 24th Apr 2025 4:15pm
Gremlin500
Yeah, similar to the lowers, it’s not easy to get the faces of the bush and bracket perfectly parallel. If the bush is even slightly tilted, it won’t go in. Before you get it any closer, put some silicone grease on the insides of the bracket and the end faces of the metal bush, to at least help align the holes later. Good luck!! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #716733 24th Apr 2025 6:28pm
will308f
right done finished(well one side ) in the end i took off the track rod then used the racket strap jacked the hub up and as i was trying to move things around hub fell off the jack but because of the strap it popped into place Thumbs Up Thumbs Up Thumbs Up Thumbs Up happy chappy .once the other side is done that's the front suspension sorted and then get the tracking done ......cheers guys
Post #716734 24th Apr 2025 6:56pm
fisha
Good job. I think this is a job thats creeping up on me in the near future. Knowing my luck, I'll probably find it a pain like you did. V8 or else ...
Post #716755 25th Apr 2025 8:00am
Gremlin500
Well done! Knuckle slipping off the jack sounds a bit dodgy, but it’s a forceful operation!
When I did my lowers, I could not crack the tapers despite lots of pounding and even heat.
I got a massive US Pro seperator for not a lot of money, and 2 minutes later, it just popped out like a cork!
Had to use the manual screw, the hydraulic ram just wouldn’t fit in, did the job easily anyway!
Bit of a pain to buy a tool to use every 5 year tho’. Rolling Eyes “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #716763 25th Apr 2025 10:52am
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Looks a strong tool. I have a multiple set of splitting tools bought from eBay in a big blue box. I had to buy something butch to get the bottom swivel joint out on a Freelander 2. In the end, I had to take the whole thing out, and get a Club Hammer and big drift to thwack it out in daylight. The arm had been bent in an accident, and straightened in the past, and the ball joint was bent. It just shows that one never knows what the last member of the bodge it and scarper family has done before you got it. I have my L322 to do on front links sometime, so useful knowledge, thanks.
Post #716766 25th Apr 2025 11:34am
will308f
i’ve got the land rover one made by laser tools 👍
Post #716768 25th Apr 2025 11:53am
