Home > In Car Electronics (L322) > DAB radio module
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Thanks, please let us know👍🏻
I will definitely fit this when you come back to us Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #715479 3rd Apr 2025 12:23pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
I have this unit: https://www.in2digi.com/products/d-jv-2/ It's working for 6 years now without any problems.
Post #715516 4th Apr 2025 10:26am
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
I'd been looking at the Indigi2 but thought it was very expensive. How have you found it, was fitting it a faff or was it relatively straight forward? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #715518 4th Apr 2025 10:40am
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Buellie wrote:
It’s in the boot, left hand side as you look from the back. Remove the cover and the DAB module is at the bottom
Hi Beullie - went DAB module hunting this afternoon, but didn’t spot one. Can you give me any further guidance based on this pic ?
Post #715596 5th Apr 2025 1:58pm
ashtrucker
From what I remember it’s that bit in yellow circle or could be on that bracket behind 2012 Westminster 4.4 tdv8
Post #715604 5th Apr 2025 3:46pm
JonnyCJ
Thanks Ash - so a bit of dismantling needed then ?
Post #715609 5th Apr 2025 5:12pm
ashtrucker
Yes thinking about it it is behind that area I market bit of a fiddle need three hands but easy when you get in there 2012 Westminster 4.4 tdv8
Post #715613 5th Apr 2025 5:42pm
JonnyCJ
Forgot to update this. DAB+ installed and working perfectly. Needs the slight tweak to select DAB on the head unit, but that’s the case for all L322 & L320 models.
Post #716747 24th Apr 2025 9:06pm
Buellie
Jonny,
So all you do is unplug the lead to the DAB module and put this connector between the unpulgged lead and the DAB module, turn it off and then on and turn the volume knob and you then have DAB+
Have I got this right? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #716793 25th Apr 2025 10:06pm
JonnyCJ
You need a DAB+ module - they go for anything between ÂŁ100 and ÂŁ250 on eBay. You then splice in the connector to replace the existing power lead and you have DAB+.
I happen have a spare, tested working DAB+ module, PM me if you want to have a chat !
Post #716807 26th Apr 2025 6:12am
