Home > In Car Electronics (L322) > DAB radio module
ashtrucker
DAB radio module
Any body ever changed there dab module and how did they do it any help would be great
Post #701701 7th Oct 2024 1:27pm
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Yes I did mine. When I bought the Car it had no DAB reception, bought a module off eBay for £40 and fitted it. Boot area passenger side (UK) remove the panel and from memory the DAB unit is near the bottom.
It's is fairly straight forward, just some nuts to undo so that some other modules can be moved aside and the DAB module has three cables to plug in I think, and jobs a good'un Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #701797 8th Oct 2024 8:19pm
ashtrucker
Thanks will give it a go when I find one for the right money
Post #701798 8th Oct 2024 8:40pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
just be aware that there is less and less on Dab as more and more are migrating over to Dab+, I got the Invery and bluetooth from apps on the phone , there is a DaB module that gives you Dab+ but its around £500 as opposed to the £80 I paid for the Invery.....
maybe worth considering? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #701800 8th Oct 2024 9:13pm
ashtrucker
Just as an update just changed DAB module not as easy as you think but job done and it works now 2012 Westminster 4.4 tdv8
Post #705718 29th Nov 2024 6:19pm
Buellie
Excellent result 👍🏻 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #705726 29th Nov 2024 7:29pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Hi Ash - can you (or anyone else) point me in the direction of the DAB unit on an L322 please ?
Going to install a DAB+ as my old school DAB is kaput.
Post #715467 3rd Apr 2025 9:56am
Buellie
It’s in the boot, left hand side as you look from the back. Remove the cover and the DAB module is at the bottom Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #715470 3rd Apr 2025 10:42am
ashtrucker
Didn’t think you could add DAB+ to l322 2012 Westminster 4.4 tdv8
Post #715471 3rd Apr 2025 11:05am
JonnyCJ
Thanks Beullie
Post #715472 3rd Apr 2025 11:05am
JonnyCJ
You can - with an adapter cable. The only thing you need to do to get it to function is to select DAB on the head unit, switch the display off then on and then turn the volume knob. I did it on my old L320 and it worked fine and lots of other L320 owners have done the same.
Post #715473 3rd Apr 2025 11:09am
Buellie
That’s interesting where can you get this adapter cable from please? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #715475 3rd Apr 2025 11:50am
JonnyCJ
Part nr is LR032814
Post #715476 3rd Apr 2025 12:01pm
Buellie
Thanks
Where and how do you fit this please? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #715477 3rd Apr 2025 12:08pm
JonnyCJ
It replaces the power lead that goes to the existing DAB module. The wires are reversed for polarity. I need to find the DAB module on my L322, so will investigate over the next couple of days.
Post #715478 3rd Apr 2025 12:17pm
