TDV8 4.4 - Mystery exhaust Pipe (+ oil leak....) | |
Hi All, hoping you can help.
I have a severe oil leak which is getting worse, too the point where I can't drive the car on the motorway (with the family) now because when you come to a halt, even after a short motorway/high speed run, the cabin fills with burning oil fumes and also smokes significantly from under the bonnet. Had the turbo oil line O-rings replaced and a new oil cooler a few months back, but hasn't solved the issue, also not coming from the front of the engine.
Having a good look under the car, I noticed this little exhaust pipe, its covered in plastic wheel arch line so can't see where it runs to, whilst under the car with the engine running, it puffed out a load of smoke.
Any of the gurus on here know what it is?!
Many thanks, Chris
