Home > Technical (L322) > TDV8 4.4 - Mystery exhaust Pipe (+ oil leak....)
CMC15
Hi All, hoping you can help.
I have a severe oil leak which is getting worse, too the point where I can't drive the car on the motorway (with the family) now because when you come to a halt, even after a short motorway/high speed run, the cabin fills with burning oil fumes and also smokes significantly from under the bonnet. Had the turbo oil line O-rings replaced and a new oil cooler a few months back, but hasn't solved the issue, also not coming from the front of the engine.
Having a good look under the car, I noticed this little exhaust pipe, its covered in plastic wheel arch line so can't see where it runs to, whilst under the car with the engine running, it puffed out a load of smoke.
Any of the gurus on here know what it is?!
Many thanks, Chris
Post #716160 15th Apr 2025 6:38pm
That's the exhaust for the FBH (fuel burning heater) Thumbs Up
Don't think it would be the reason for you leak though...!! Pete
Post #716168 15th Apr 2025 8:32pm
kevinp
It should only work when the outside temperature is low and if it does smoke badly it's because the combustion chamber inside the FBH is all clogged up.
Just changed mine and no more smoke.
Post #716170 15th Apr 2025 9:58pm
CMC15
Thanks gents.
Much appreciated.
Post #716559 22nd Apr 2025 2:35pm
