![]() | Home > Technical (L322) > P040D - DPF Temp sensor failure .... HELP!!!! |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 229 ![]() ![]() ![]() |
P040D? That’s the EGR temperature sensor. Shouldn’t affect a DPF regen. |
Crusty21 Member Since: 29 Mar 2022 Location: Cheshire Posts: 41 ![]() ![]() ![]() |
P040D-00 (2F) Exhaust gas recirculation temperature sensor A
I think this explains it better Pete
Myself and others have had this fault code for years with no problems at all. Maybe there’s some other reason why it won’t regen. Is the Red DPF light on? I changed mine last year so i know which sensor it is. |
No red light on Pete
If it’s running ok and that’s the only engine fault code I’d leave it. Mine was on for years with no affect at all. I only decided to change it to get rid of the fault code. Do not try to do a forced regeneration with no reason to. |
Not sure I would feel comfortable leaving it Pete ...... just found this bit of info .....
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
It’s ten years since I bought my Gap iid and the PO 40 (D) was showing then , and is still showing now.
Thanks mike
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
That usually does not impact DPF regenerations. Have you had any yellow DPF warning lights? If not, carry on |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 760 ![]() ![]() |
+1 for the "leave it alone" gang
In the 5+ years of having the P040D-00(2F) fault on mine I’d never in that time had a yellow or red DPF warning. No problems with regenerations or running issues at all. |
Dr Rob ..... I've been in touch with James today ... just waiting for him to call back to get his take on this |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 519 ![]() ![]() |
My L322 4.4TDV8 had that error code (P040D-00 (2F) Exhaust gas recirculation temperature sensor A ) and I was very upfront about it when I sold the vehicle. Even reflected it in the price (looking back, I sold that car wayyyy too cheap though).
