![]() | Home > Technical (L322) > P040D - DPF Temp sensor failure .... HELP!!!! |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 758 ![]() ![]() |
"If the failed sensor doesn't affect DPF regen, mpg or any other "processes" then would you have any idea what its function is? "
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 905 ![]() ![]() ![]() |
its common
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 519 ![]() ![]() |
That's a fair question, and yes it must perform some function, manufacturers don't add parts just for fun! ![]() I'm not exactly sure what the ECU does with that sensor's measured temperature values, though. I just know the TDV8 engine seem unaffected by that error code and many people just live with it, due to the limited access issues (manifold heat shield) on the L322 installation and the risk of snapping the sensor off. Certainly, it's not a significant enough error to bring up the Engine Management warning light on the dash. I do seem to remember from another discussion on this topic, that the ECU calculates an interpreted value if that sensor isn't providing an 'expected' value, or is giving a short to earth fault. But can't say that with total certainty, as I can't find that information any more. As others have said, that fault code should not affect DPF regen's occurring. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Crusty21 Member Since: 29 Mar 2022 Location: Cheshire Posts: 41 ![]() ![]() ![]() |
Many thanks Jon |
