![]() | Home > Technical (L322) > Med Speed CAN Bus Problem No Start (Solved) |
buck66 Member Since: 28 Feb 2016 Location: Ontario Posts: 5 ![]() ![]() ![]() |
Hopefully this post helps someone if they experience a similar problem as I did over the last 11 months. My problems started last summer and have continued intermittently since then. My problem was first reported within the following post:
Thanks Graeme, yes I originally thought the problem was one of the ECU's or the Central Junction Box. I was not looking forward to digging into the CJB. The folks at GAP thought it was more likely a wiring problem and specifically a short to ground or short to 12V. I spent a lot of time reading about the CAN Bus system how it works, locations of ECUs etc. If a single ECU goes down it doesn't typically cause the entire network to go down. Similiarly corroded connections would lead to Non-communicating fault codes passed that point in the network, everything upstream would typically still function normally. For these reasons and likely a few others GAP pointed to short circuits in the network. The short circuits would prevent all ECUs from transmitting any useful data between each other. As a result the Fault Codes read by both my NanoCom and the IID BT tool were Non-communication faults between every ECU on the MS CAN network.
Update
LR3Trav Member Since: 17 Nov 2016 Location: Chula Vista, CA Posts: 17 ![]() ![]() ![]() |
Thank you for the write up. I just lost my radio today and used the GAP IID Tool and got the codes for "Control Module Output Power A - General Electrical failure - circuit short to ground or open"
Sounds a little different. Mine had faults for most if not all modules on the Med Speed CAN bus. If you just have the one listed for the radio it maybe more localized. |
libbyn Member Since: 16 Apr 2025 Location: Arizona Posts: 1 ![]() ![]() |
Hi Buck66,
