Home > In Car Electronics (L322) > 07 L322 Display stuck in Land Rover logo / no sound
lucasvrooij
Netherlands 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hello everyone,
A new member from the Netherlands here, had an 03 L322 4.4 with BMW's M62 before, now got myself a facelifted l322 with the 3.6TDV8 and absolutely loving how it drives. Also my absolute dream spec with Buckingham Blue over cream interior.
Bought it with a display that was completely black, removed most of the dashboard to replace it but it turned out someone had removed the fuse.. a good reminder to always check the basics first...
I have checked all the relevant topics on the forum but none of the usual solutions like bypassing the bluetooth module seem to work for me.
Anyway current situation:
Head unit display stuck on Land Rover logo and orange light blinking. Have entered the unit trough the diagnostics menu but wasn't able to get sound. If I go to the audio section CD and DVD are greyed out, AUX is not but can't select it either. So stuck in radio mode but only shows me presets that seem to have nothing behind them.
Have tried:
- Bypassing bluetooth module in the rear with a MOST loop and doing a battery reset (disconnect battery for a few mins)
- Bypassing the other 2 modules in the rear (I believe TV and TMS) with the most loop and also battery resetting
- Checked all the relevant fuses
- CD changed had the fuse pulled but inserting fuse and doing a battery reset hasn't worked
Considering to do next:
- Check IHU unit connections in glovebox area
- Bypass CD changer in Glovebox area with Most loop
- Remove amplifier rear left and have it inspected
Other relevant info:
- Buy more MOST loops to loop multiple modules at the same time in the rear left
- IHU and CD changer fuses where pulled when I got the car
- Saw quite a bit of corrosion in the glovebox area when I removed the dash
- Quite some corrosion on the TV unit rear left but other modules don't seem that impacted
- A large black connector is lying loose in the rear left compartment but I've seen video's where others have that as well so maybe that is for a module that is not present in mine.
If anyone with knowledge of this system could have a think along that would be massively appreciated. Greetings from Holland![/b]
Post #712690 24th Feb 2025 12:54pm
MariusRR
Norway 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Hi
Did you ever find a sollution here?
Best regards from Norway
Post #715859 9th Apr 2025 8:53pm
lucasvrooij
Partially, bypassing the bouetooth module AND the TMC module in the rear left compartiment got the nav display working again. However I am still stuck on the radio function and cannot use AUX.
Post #715860 9th Apr 2025 9:00pm
MariusRR
Thanks. I have all the same problems. I have a fiber optic signal to the TMC unit. But it stops there. If i unplug and plug in the tmc module it creates a signal for 30 seconds. But i thought the signal startet in the head unit og unit before ut. I have bought a lot of the units for this used now. Will let you know if that solves anything
Post #715861 9th Apr 2025 9:03pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Check the CD changer in the glovebox
I have read posts related to the problem being a dead CD changer. Getting it out to test this is a bit tricky - but you can see if you have a laser light on the connector (going into the CD Changer , then the outbound one) to see if thats not the problem).
Some people installed the IPOD adapter int the glovebox - that also might be an issue if not installed correctly - or removed, and the cables not being plugged in correctly so there is a MOST Loop 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #715914 10th Apr 2025 5:37pm
