![]() | Home > Technical (L405) > Do Deployable Steps Need Calibrating? |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 367 ![]() ![]() ![]() |
My NS step was stuck out for some time. The usual seized hinges. That prompted me to buy a load of them and the motors, and put them in stock (apparently, you often need to change the motor with the hinge as it can get damaged when you are removing the hinge).
Bikeracer Member Since: 24 Aug 2023 Location: Newark Posts: 17 ![]() ![]() ![]() |
I've had both mine done and fitted with OEM motors and hinges. I've just contacted my garage and he said they are just fit and plug in, no calibration.
fez Member Since: 24 Jan 2025 Location: UK Posts: 8 ![]() ![]() ![]() |
Stuart did you ever manage to resolve the issue? |
It's booked into Sytner to have it done. I'll update when done.
KN Member Since: 07 Jan 2025 Location: Chandigarh Posts: 8 ![]() ![]() |
Mine left step was stuck open. I thought of carbon brushes of motor stuck. Opened motor and replaced jammed bearing 6003zz of gear, driven by motor. I separated motor and hinge. Also operated without hinge for testing. What I did was....There is millinig on the motor shaft while motor is not filtted door is open and step is fully deployed fit the motor and put the tapered piece in between motor and hinge and tighten the LN key bolt. Standard 2000 (Rover Sd1) 1989 - 1992
Mine is L322. I don't think it needs calibration by any software. Standard 2000 (Rover Sd1) 1989 - 1992
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 77 ![]() ![]() ![]() |
There's a chance they assembled them wrong and the wedge that locks the shaft in isn't seated correctly. I swapped the motor on mine with no calibration required, they work on resistance to detect when the step is at the end of it travel |
So trying a couple of things and just come to the conclusion that the old motor and the new ones are about quarter of a rotation from where they need to be.
