Home > Technical (L405) > Do Deployable Steps Need Calibrating?
Stuart-
My NS step was stuck out for some time. The usual seized hinges. That prompted me to buy a load of them and the motors, and put them in stock (apparently, you often need to change the motor with the hinge as it can get damaged when you are removing the hinge).
So I put the car in the indy, they replaced both hinges and the motor. I collected it, they said it was now fine. I trundled out to test it, unlocked the car, it popped out all the way and immediately went back in again. Big Cry
It did come out and stay out more successfully when the back door was opened, but not the passenger door.
I went back in and questioned this, and they said they had had much difficulty calibrating them, and they thought they'd managed it as it worked fine when they tested it. But it ain't working properly now.
I asked what might be done, and they all stood about saying "erm" and speculating about the software on whatever they use to do this. So that was that, really.
Is it true they need calibrating after a hinge/motor swap? Is it something that needs to be done with the computer or does a hard reset do it? They suggested a trip to the main dealer to have it done. Which kind of defeats the object of using an indy, doesn't it?
Does anyone have any experience of this? 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #714516 20th Mar 2025 7:51pm
fez
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Montalcino Red
Hi Stuart, let me know if the trip to Sytner manged to resolve this, other than what you have mentioned haven't found anything about calibration for the steps. Thank fingers crossed it resolves it for you.
Post #715247 31st Mar 2025 10:10am
Bikeracer
United Kingdom 2014 Range Rover Vogue SE SDV8 Nara Bronze
I've had both mine done and fitted with OEM motors and hinges. I've just contacted my garage and he said they are just fit and plug in, no calibration.
The motors came with new hinges, just had to fit the old existing step back on.
Hope this helps.
Post #715337 1st Apr 2025 12:47pm
