![]() | Home > In Car Electronics (L322) > No audio, no display. |
Johnniehec Member Since: 03 Feb 2017 Location: A a Posts: 28 ![]() ![]() |
Follow up. On closer inspection, yes there does seem to be minor water ingress in the boot. Looped the fibre on the Nokia Bluetooth module, no change. Consensus of opinion on other forums it’s probably the amp. Very difficult to see if there was evidence of water damage to the amp in situ and what a pain to remove it. All the other components have to come out and all the wiring looms/connectors pulled out of the way before the bracket with it and the TV tuner are on can come out. No evidence of water damage on any of the connectors and only a small water stain on the top edge. Opened it up and found a couple of very small areas of corrosion so going to get a second hand replacement, am I correct to say better get one out of a Discovery as they’re under the seat and less likely to have had water ingress? Also with everything removed and unplugged, with the ignition on, should one of the fibres from the front be lit?
Varks74 Member Since: 03 Apr 2025 Location: Cornwall UK Posts: 12 ![]() ![]() ![]() |
John, I have exactly the same symptoms on mine, no life in the screen and no orange power light and no visible light from the fibre optics either although the buttons do light up when the lights are on, the previous owner changed the amp to no avail, im not sure if that needs coding to the rest of the system now or not? i do have a new touch screen that came with the car as well as the original amp,
Varks74, I bought another amp from eBay out of a L320, figuring as they’re under the seat it shouldn’t be water damaged. Have had it for a while, have now got a hybrid TV module too as mine was analog only. Cleaned some rust off a couple of the mounting brackets and painted them last night, going to have a go at refitting all tonight, I’ll post an update when I’m done. |
good luck, I will try and find time over the weekend to sort mine out, I have a spare amp and screen, the previous owner changed the amp to no avail, hoping i find something obvious in the rear before having to strip the dash down to get to the touch screen, |
@Varks74 Sorry I didn’t get to it the other night, but I have this afternoon. Replacement amp fitted and all is working correctly now. As I changed the tv module to a hybrid one I’ve now got tv as well. No coding or config changes for either module. I’ve fitted a plastic card, is actually a cheap chopping board, pack of three from Tesco, down the back of the modules to deflect any incoming water. |
Johnniehec, that's great news, i am tearing my hair out with mine, i presumed that because the previous owner replaced the amp that it wouldn't have been the issue, i may need to take the lot out like you have and start from scratch, i did it the other day but did it all through the hatch, i think i may need to take the whole boot side tray out this time, there is some signs of surface rust on the frames but can't see any corrosion on any of the units,
There was no obvious sign of damage outside the amp, it wasn’t until I opened it I saw three separate small pieces of corrosion amongst the components. The replacement was same model and part number but out of a Disco 3. The TV module is RANGE ROVER L322 007 TV HYBRID MODULE XRA500070, although the part number and label says L322 it’s out of a Sport. I don’t think I could have done it without taking out the left boot well cover support, it has 3x 10mm plastic fixing nuts, there’s a plastic stud through it at the front where the speaker cover trim fits( don’t need to take the speaker trim off, the support will prize from under it after you’ve undone the load securing loop allen bolt and removed the trim up the side of the tailgate. Good luck. |
hopefully i won't need to delve into the depths of the rear quarter this time, i am hanging all my hopes on it being the integrated head unit, did a lot of searching on the net yesterday and also managed to scan for the codes to do with the infotainment system, a couple of guys have had exactly the same symptoms and theirs ended up being the IHU,
