Home > Technical (L322) > Part number for special washer on front anti roll bar links?
Brandon318
United States 2009 Range Rover HSE 4.4 V8 Santorini Black
Found out today when replacing my front sway bar links that the so-called “special washer” that RAVE point out is missing and might be the reason for my front end clunk.
Any part number available to replace it?
Post #715571 5th Apr 2025 3:41am
p38arover
Australia
Is this it?
https://rimmerbros.com/Item--i-RGI000012
No, according to lrcat.com, that's for the rear suspension. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #715574 5th Apr 2025 8:03am
GraemeS
Australia
It is just a washer that is fitted between the joint and the bracket. D350 SE Carpathian Grey D5 19" rims
Post #715591 5th Apr 2025 12:02pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
[img]Part no. is RYF000021
it supercedes RYF000020 for pre 2006 - don't understand what the difference is as both are a simple large outside diameter hardened steel washer for M12 bolts.
Beware some sellers have some bizarre "restrictor washer" as the same item & it isn't the same thing !
Paul
[/img] Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #715602 5th Apr 2025 3:07pm
