![]() | Home > Maintenance & Mods (L405) > Oil cooler and coolant leak... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8529 ![]() ![]() ![]() |
I've had a search but now more confused than ever (doesn't take much) I have a leak down the back of the engine and bellhousing you can see drips quite high up and this at the bottom...
So I take it this comes from either the oil cooler (replaced 3 years ago) or some "O" rings nearby or from a pipe to the thermostat housing.... So a few questions Is it worth just changing the lot and if so what parts, "O" rings etc are "the lot"...?? Or should I just take it apart and see what's leaking...?? Any other help or ideas please let me know... Cheers ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
I base my decision on how long you intend to keep your car.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
I suggest that you remove the donut to have a look for the source(s). If it's just the o-rings at the back then you might continue to replace them. My Viton ones needed to be replaced again at about the same interval. MY21.5 D350 Vogue SE Carpathian Grey |
BAZ8046 Member Since: 26 May 2023 Location: Chatham Posts: 35 ![]() ![]() ![]() |
When I had a coolant leak showing at the back it was from the bottom of the thermostat housing.
2016 Discovery 4 Landmark 2002 Defender TD5 |
Mike, Much what I was thinking...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Strip down of the top of engine stuff is pretty straight forward Pete. It all looks tight but once you have the secondary bulkhead and plenum off then you can see most of it. |
Cheers for that, just trying to make sure I have all the bits so it's not off the road for long... |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 234 ![]() ![]() |
This may help: https://www.fullfatrr.com/forum/topic66813...+hose+seal 2012 Vogue TDV8 in Aintree green over sand |
Cheers, I knew I'd seen that somewhere, used search, never found it...... Pete
BS611 Viton are good fit o-rings on the turbo oil feed fitting. MY21.5 D350 Vogue SE Carpathian Grey |
Cheers, do you happen to know the size of them...?? Pete
BS611 has ID 8.73mm and CS 1.78mm (OD 12.29mm)
Cheers... |
I've bought some "O" rings...
